Question about Casio FX-9750GPlus Calculator
How can I solve 3 equations with 3 variables using casio fx-3650P ?? please
Solving equations with variables? e.g 2+x=3
This calculator does not have an equation solving routine. You will have to solve it by hand. Try to guess what number, which added to 2 gives a sum of 3? You have it! x=1
Sep 07, 2013 | Casio fx-300ES Calculator
Equation mode in casio115W
Sorry, the Fx-115W is unable to solve equations of any type. In addition to that, the more sophisticated Casios such as the FX-991 ES solve linear equations of no more than 3 variables.
Sep 09, 2012 | Casio FX-115W Plus Calculator
How to solve equations with two variables by usin CASIO fx901 calculater? eg- 6x+9y=2700 5x+4y=1560
The FX-901 calculator seems to be the equivalent of the FX 260 Solar sold in North America. It does fraction calculations, permutation, statistics but lack the Equation Solver.
You cannot use it to solve equations.
Casio Scientific calculators that can handle equation solving are the FX-115 and FX-991.
Simplify your first equation by dividing all its terms by 3, then use elimination to carry out the solution by hand.
Sep 02, 2012 | Office Equipment & Supplies
Edit Casio FX - 9860G SD have complex equations??
Thhe Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Addendum.
The calculator CANNOT solve equations with complex coefficient. YOU can however convert the system of linear equations with ccomplex coefficients ( of the type you show) as a system of 4 linear equations in 4 unknowns; Split x into a real and an imaginary part, split y into a real and an imaginary part. Substitute Real(x)+iIm(x) for variable x in the equations; substitute Real(y)+iIm(y) for y in the two equations; do the algebra. In each of the original equations split the Real and imaginary parts. You should be able to derive 4 linear equations in unknowns Real(x), Im(x), Real(y), and Im(y).
Use the linear equation solver to obtain the solutions. Recompose x=Real(x)+iIm(x), and y=Real(y)+iIm(y)
Alternatively, after you create the system of 4 linear equations you can use the matrix utility to find Real(x), Im(x), Real(y) and Im(y) and recompose the x and y.
Mar 17, 2012 | Casio FX-9860G Graphic Calculator
Casio FX - 9860G SD have complex equations?? edit
The Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Addendum.
Mar 17, 2012 | Casio Office Equipment & Supplies
How do I solve for y, 2y + (y-3)=18 - 2 (y+3). with the casio fx-300es? and if I cant whats the calculator that will. thanx
Do you really need a calculator to solve a linear equation?
Let us see how to solve it without a calculator.
Remove the parentheses fronm the second term on the left : y-3
Use the distributive property on the last term on the right side -2y-6
Take the term -3 to the right side, changing its sign in the process (becomes +3)
Take the -2y term to the left making it +2y.
3y +2y=18+3-6 or 5y=15 and the answer is straightforward .
As to your Casio FX300ES, it cannot solve equations because it does not have an EQUATION calculation mode. The Casios FX-115ES and FX-991ES have an Equation Mode. If you use any of the two to solve an equation in one variable (linear, quadratic or other) the unknown is taken to be x by default. You would have to change the name of the variable from y to x.
Sep 08, 2011 | Casio fx-300ES Calculator
Solving linear equations in 3 variables by matrix method in casio fx-115ES
Press key Mode, first select option 5:EQN (by pressing key 5), then option 2: a_nX+b_nY+c_nZ=d_n (by pressin 2).
Now input coefficients from equations in table (each column is for one variable), just type in number and press =, then use arrows to move to another cell.
Sep 02, 2011 | Casio FX-115ES Scientific Calculator
I m unable to multiply two 4 cross 4 matrix ,how to solve this problem?
This calculator cannot handle matrices that have anyone dimension larger than 3.
How to solve your problem?
  1. Set up the problem by hand (pencil paper): use Cramer's rules. Make use of the calculator to perform the various calculation.
OR
  1. Sacrifice one equation which you will use to eliminate one variable of the 4 by expressing it in terms of the other three. Do the algebra to obtain a system of 3 equations in three unknowns.
  2. Use the calculator to find the solutions ( the three variables that are left).
  3. Use the 4th equation (the one you scacrificed) to obtain the value of the 4th unknown.
OR
use a computer program devoted to solving linear equations
OR buy another calculator that can handle larger systems of equations (a graphing calculator, maybe).
Feb 16, 2011 | Casio FX-115ES Scientific Calculator
Casio fx-7400G PLUS cubic solver?
First let us repair the terminology.
  1. You can evaluate any expression (find the value of any expression for a particular value of its variable).Store a value in the variable, say X. Key in the expression and press [EXE].
  2. You can consider your expression(should not contain a relational operator such as =, greater than, less than, greater than or equal to, less than or equal to) to be a function Y1(x) = expression and graph it, or generate a table for it. You will have several values of the function calculated at various points.
  3. You can set your expression equal to 0 and find the particular value(s) of the variable (the unknown) that make the equality TRUE. That is called solving an equation.
I am not sure that it has a solver (solving an equation or an inequation) but you can always draw your expression as a function and explore the graph (SKTCH) to locate the roots (or zeros) of the functions (the values of the variable where the function equals zero.) That is called solving graphically.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Nov 05, 2009 | Casio FX-7400G Plus Calculator
Want to solve quadratic equations on my casio 3650p super fx
In your manual, Appendix Program Library, (Page A1) you have the listing of the problem to solve the quadratic equation. Type it in your calculator and execute it.
Hope it helps.
Aug 13, 2009 | Casio FX-9750GPlus Calculator
Casio FX-9750GPlus Calculator Logo
75 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
