Question about KitchenAid 24 in. KUDP01DL Built-in Dishwasher
What should be the incoming water temparature to make the system work properly
  • KitchenAid Master
  • 43,501 Answers
Most dishwashers want at least 120F water for good operation...
heatman101
Posted on Oct 16, 2010
The Boiler , fans, all stat running. Thermostat won't shut Boiler off.
a lot of boiler systems the stats do not shut off the boiler, but once the boiler water temparature is reached its fully heating tempaerature of 180 deg fahr, then it,ll shut off
Feb 27, 2016 | Heating & Cooling
W have a amanda ref model AF12538AEW SER#12987374LX putin to storage a year ago. Worked fine. Pulled it out of storage. Freezer get 34deg. Ref 40 deg. Any thought whats wrong?
THE UNIT HAS MOLD BUILD UP IN THE EVAP COIL IT NEEDS TO BE CLEANED PROPERLY BY REMOVING THE FREEZER RACKS AND THE SCREWS IN THE REAR OF FREEZER COMPARTMENT THEN USE HOT SOAPY WATER IN A SPRAY BOTTLE AND CLEAN THE EVAP COIL AND MAKE SURE THAT THE DRAIN TUBE ISNT CLOGGED REINSTALL PARTS THEN TURN ON BOX CHECK TEMPARATURES. FOOD AND MOLD GETS INTO THE EVAP COIL AND MOVING DOORS AND FLAPS AND AIR PASSAGES CLEAN UNIT WITH HOT WATER AND BLEACH MIXTURE TO KILL MOLD SPRAY OUT ENTIRE BOX WITH MIXTURE OF SOAP AND BLEACH WATER AND RINSE COMPLETELY
May 04, 2015 | Refrigerators
Recently installed a Noritz NRCP 112 water heater, but very frequently it keeps shutting off and on the display it says error 60, after looking at the manual there is no explanation of what error 60 is....
Shut downs with new heater might be defective PC board.
Other issues could be associated with improper installation.
Low gas pressure caused by undersized gas meter or water in the gas line, undersized gas line to unit (requires 1" gas line to within 10 feet and then 3/4"), wrong type of gas line (cannot use flexible gas line), improper vent (for example too long horizontal run or undersized vent pipe or shared vent with furnace or other gas appliance), not enough incoming fresh air supply, nearby exhaust fans or vent fans stopping proper draft on tankless, temperature set too high for cold incoming water supply (install tempering tank to help preheat water),..
http://waterheatertimer.org/Tempering-tank.html
Other causes can be clogged water filter located where cold water enters tankless, or clogged water line, or crossover caused by bad single-handled faucet or bad crossover valve on recirculation system, improperly sized recirculation system. These problems can mean less water flow through tankless, so burner shuts down, and unit throws error code because sensor indicates water flow is still moving but inadequate to trigger burner
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
Gene
Water Heater Timers Save Money
Nov 27, 2014 | Water Heaters
Manual
Those machines use the incoming water temp to start and then boost it, so check the incoming water temp. If it is too low then you need to increase it. It could be the heater that is not working but you need to check the incoming water temp first.
Jun 06, 2013 | Jet Tech Systems 24 in. F18DP...
Water from Elkay wall mount water cooler is coming out cloudy. I know it has air in system and i let water run for over 5 mins but water remains cloudy. Looing for solution
  • Check the water shut off valve is not open all of the way if not open shut off valve all of the way.
  • Check to see if the regulator / control valve is restricted with debris or not working properly. If so clean debris or replace the control valve.
  • Check the water inlet screen is for debris, clean or replace screen
  • If there is an external water filter, check to make sure it is not clogged.Check the income water line, if flexible, to make sure it is not kinked, is it is rework it to remove the kink.
    Dec 06, 2012 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
    I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
    Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
    Jul 18, 2011 | Intex Automatic Salt Water System for ...
    Temparature and pressure relief valve seem to be leaking continuously
    1) Lift TP lever and lower back down to dislodge anything stuck in valve
    2) Replace TP valve with generic one from hardware store
    Steps for replacing valve are shown on link below
    http://waterheatertimer.org/How-to-replace-TP-valve.html
    Jan 11, 2011 | General Electric GE SmartWater Household...
    The bottom element in oven seems to only preheat to about 250 degress
    you can adjust the temparature settings by increasing the it to get higher temparatures. if that doesent work then check that the all the elements in the bottom oven are working and not burnt out, you can replace the bad ones
    Aug 15, 2010 | Ovens
    My temparature light is on and flashing. . .what
    Drive it as little as possible until fixed!!!! It means it is probably getting to hot. You may be low on coolant, or you have a leak of coolant. Or your water pump could be going bad. If you drive it while it is to hot the results could be catostrophic.
    Dec 28, 2009 | 2002 Volkswagen Jetta TDI
    KitchenAid 24 in. KUDP01DL Built-in Dishwasher Logo
    Top KitchenAid Dishwashers Experts
    Mike
    Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
