How to replace the Power Supply in HP 8756c
How do I replace the Power Supply in HP 8756c. I can't figure out how to get to the ATX connection on the MB. I've removed the drives, RAM. How can I get to this connector. I'e looked up this on HP support page, and they don't even let you download a manual.
  • Anonymous Jun 18, 2008
    This power supply connector is the hardest I've ever encountered.
    What is wrong with these HP people?!?!? You can't even remove the plate that holds the motherboard for easy access to the connector!!!
    Jeez!
The rack that holds all the drives slides out the front. You need to remove the screws and pull the tab-a picture is here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph05592&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&man_lang=en&os=228&product=58195#N297
Posted on Jan 04, 2013
  • 85 Answers
Dondexta,
Here is a link to mb.
Check top right corner.
Posted on Jun 03, 2008
  • Frank Cox Jan 04, 2013
    The disk cage slides out the front allowing access to power plug etc.http://h10025.www1.hp.com/ewfrf/wc/docum...
Does a solid green light mean the power supply is ok when disconnected from motherboard and drives, ATX-300-12Z
Not necessarily. The green light usually just signifies power to the power supply. Amazon sells a cheap power supply tester that can verify everything on a power supply from old to new.
Jul 21, 2014 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Having problems with Bestec ATX-300-12z power supply.
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... This is a common power supply that can be purchased just about any computer retailer - BestBuy, MicroCenter, Amazon.
Very cheaply priced, very functional. Even the generic brands.
Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection.
Nov 14, 2012 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
There is any different between this mother board p/n 51884327 and p/n 51882625
Take the power supply to a retailer or computer shop in your local area. Pretty standard from what I have found out.
Bestec ATX 300 12Z Rev DDR Replacement Power Supply HP 5188 2625 Have a great day.
Jul 29, 2012 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Pin layout for orion 585w
There is only one way you can connect your power supply. The connection is pinned to only go in one way. ALSO: The power supply is very inexpensive and can most likely be bought from any of your computer retailers, Amazon - Just make sure to confirm the right model type of power supply. BEST to have it tested before replacing it. To make sure that is the issue..
Oct 20, 2011 | HP HEC HP585D 585W ORION HP585D ATX 12V...
Hp pavilion a430n power supply is blinking
Look at this photo
(http://www.atxpowersupplies.com/images/300-watt-atx-power-supply-FSP-ATX-300GU-350w.gif)
Did you connect the p4 atx 12vx1 plug?
You may also need to connect the aux x1 plug on some models.
Mar 08, 2010 | HP Pavilion a430n PC Desktop
I have a burned out Bestec ATX-250-12z power supply for a hp pavilion a320n. I need to know if a Dynex® - 400-Watt ATX CPU Power Supply, will work in its place.
yes it should do provided your current psu is not a small mATX one. ATX power supplies are pretty generic. Make sure you get one that has enough connectors to suit your system, having said that, Considering it's an off the shelf PC I would guess most PSU's would have the right number and type of connections.
Jan 10, 2010 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Do you have the connector pin identifiers for a DPS-160BG supply ? My HP 8756c died, and I am not sure if it is the motherbopard or the supply that is bad. It behaves as if it was not even plugged into ac...
it your ac main change it out with the correct type or u will wish u had of and also b4 u do that take iot to a shop and see if they can get u what u need for it
Nov 18, 2009 | HP Pavilion 8756C PC Desktop
No Power out put.
short the color green and black of your atx... use a metal wire.. don't wory it won't harm you... just unplug all the connection that is connected from you ATX.... short the said wire then plug your ATX to the outlet.. if fan is running then there's no problem on your ATX.. if not then you need to replace a new one...
Jul 20, 2009 | HP Bestec ATX-1956D 200w HP Part No...
ATX power supply compatible with my EVO D500 Motherboard
If your motherboard is wtx connection , pretty sure that there are 2 ports in it. the 24 pins and the 22pin. so maybe you need a WTX power supply which is availbale today. this is tha example (http://images.google.com.ph/imgres?imgurl=http://www.acmemicro.com/estore/prodimg/PS-ZP-T6460.jpg&imgrefurl=http://www.acmemicro.com/estore/merchant.ihtml%3Fpid%3D840%26lastcatid%3D59%26step%3D4&usg=__Ox5OtEG9zc7AqUAus-hrVrOEvyA=&h=180&w=180&sz=8&hl=tl&start=1&tbnid=yrGwUf_iyMZMxM:&tbnh=101&tbnw=101&prev=/images%3Fq%3Dwtx%2Bpower%2Bsupply%26gbv%3D2%26hl%3Dtl%26sa%3DG)
maybe you can find a PSU for your stuff in that link.
may this help,
melnavz
Feb 15, 2009 | Computers & Internet
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
