Question about Samsung B2430H 24Inch Widescreen LCD Monitor Glossy Black TV
MNTR SMSNG|LCD 24" 5MS B2430HD RT I am looking for the screw size to mount this monitor to a vesa comapatible wall mount.
Sansung Custermer Service told me these screws were an odd size and offered to send the screws to me. 8 week and 6 phone calls later and still no screws!!
I have tried M5 and M4 and both were too large. I'm trying to source M3's and hope they will fit, otherwise I'll return the TV to Costco.....
Posted on Dec 29, 2010
  • rosebay_ns Jan 04, 2011
    I finally got an answer today. Samsung use the “VESA” standard for their wall mount screw spacing on the rear of this TV but they have a used a non-standard thread (go figure). Mounting screws to match their thread are not available but Samsung say they will supply studs so that the regular M4 screws normally packed with purchased wall mounts will work.
  • d_begin Aug 21, 2011
    Finally, did you received the studs so that the regular M4 screws normally packed with purchased wall mounts will work ?
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
Need to remove monitor stand
should be four screws holding it on. Take them off and keep them safe. The monitor is made to take this off and mount to a VESA square block plate for wall-mount etc.. look and you will see them there.
Dec 29, 2013 | Envision EN7410 17" LCD Monitor
What is wall mount vesa specs for sharp LC-29LE440M?
This concept was launched originally in the year 1997 and it was called FPMMPMi or Flat Panel Monitor Physical Mounting Interface. Later, it was shortened to FDMI or Flat Display Mounting Interface. Screws are mostly included in VESA wall mounting hardware but they are also sold at hardware stores.
Feb 14, 2013 | Chief Manufacturing Thinstall MSTU...
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
HI , I'm looking for the size of the mounting bolts that would be required to mount a 32 inch Sony LCD TV.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Apr 03, 2011 | Televison & Video
I'm trying to hang my tv "Lcd Thomson 32E92NH22"
in the manual there is now screw size specified. there is only a notice about VESA mounts.
here is a link to the manual, so you can have a look yourself: http://safemanuals.com/user-guide-instructions-owner-manual/THOMSON/32LB130S5-_E
greets, b.
Mar 01, 2011 | Thomson 32LB130S5 32 in. LCD TV
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
Philips tv mounting problems
did you ever find a solution for this? the same thing happened to me, and now philips wont repair the mounting hole. I am so mad and will never buy another Philips again!
Dec 26, 2009 | Philips 42PFL3704D LCD TV
Samsung B2430H 24Inch Widescreen LCD Monitor Glossy Black TV Logo
713 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
