Question about JVC THC5 Home Theater System with 5-Disc DVD Changer System
5-disk autochanger I moved and was re-setting up my system...the controller unit was turned up-side down and I heard what I thought was a disk "move" inside. I inspected the unit to see, but no disk were inside. I removed the cover and then removed the autochanger itself. There is what appears to be a disk tray (not the tray the disks are loaded into, but one they appear to be moved to for play) - that has been "disloged" and was loose in the unit. I'm sure that I can put it back in (it doesn't appear to be broken), but I can't figure out how/where it is supposed to be installed. Do you have a diagram of how it is "supposed" to be assembled? Please help. Thank you
  • 2 more comments
  • irishlucky Jun 02, 2008
    This is a JVC THC 5 Home Theatre System
    I'm not looking for an "instruction manual" or a "users guide"....I need an exploded view of the autochanger. (I don't need a wiring schematic)
    I've got 3 photo's....where do I send them?
  • irishlucky Jun 04, 2008
    The metal cover SM1-1M cannot be removed, at least not easily.
    I removed the white plastic cover shown above it that is attached with two screws. This houses the disc trays.
    The tray installed above the disc trays, in the orientation you suggested.
  • 3,037 Answers
Since diagrams are very scarce for these types of system, I suggest contacting the manufacturer at (800) 252-5722 or and they should be able to get someone who can help you out with either a diagram through email or by step by step directions. Let me know if they are unable and I will see what else I can do or who I can find to get what you need.
good luck
Posted on Jun 02, 2008
  • 3 more comments
  • Benjamin Patri
    Benjamin Patri Jun 02, 2008
    yes I know you don't want a manual but companies are very protective about documents like you are needing and so if you explain the situation, they should help you otherwise you may have to send a picture and send it to me so I can tell you what to do
  • Benjamin Patri
    Benjamin Patri Jun 02, 2008 like I posted in your other thread, I will reply as soon as I can after you send them
  • Benjamin Patri
    Benjamin Patri Jun 03, 2008
    alright, so to start you will want to remove the top metal piece with the big SM1-1M on it. The black tray goes in with the open end facing in and it is right-side up in the picture and should go in with only a 90 degree clockwise turn.
    There is a white tab with a metal arm on the top left of the second picture, the tray should attach to this. The assembly on the bottom moves vertically. I am unable to clearly see any other points of connection on the top sides but the tray should hook at the top and if you are still having trouble getting it to connect, then please take a side picture of both sides on the inside preferably with the top off but I hope this helps
  • Benjamin Patri
    Benjamin Patri Jun 04, 2008
    sounds good, if everything is fixed and working now, feel free to rate my solution for feedback purposes and if you need any more help, feel free to contact me here otherwise have a good day
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • 555 Answers
This product manual should be able to guide you in the reinstallation of this piece.
When i moved my kic chest freezer model kc0021-Aa, I heard an light explosive sound and now the freezer does not go on.
The following is the GE moving instructions. If you have started before the 24 hour rest period and the unit had been rotated from vertical have the compressor inspected.
FREEZER MOVING INSTRUCTIONS Please use the following steps when relocating an upright or chest freezer:
  1. Disconnect the power cord from the wall receptacle.
  2. Remove the food, defrost, and clean the freezer.
  3. Use blankets to protect the freezer finish from scratches.
  4. Place the freezer on its side for moving only if you have no other choice.
  5. When transporting a freezer, keep it in an upright position. If transporting it in an upright position is not possible, lay it down on the compressor side of the unit. Be careful to secure the door to prevent it from opening.
  6. If it has been transported on its side, set it right side up in its final location and allow the freezer to sit for the same amount of time that it was on its side (24 hrs max.). Do not plug the unit into the electrical receptacle without allowing this settling time. The unit can be damaged if it is plugged in prematurely.
If the unit was transported in an upright position there is no waiting time required.
Hope this helps?
Apr 07, 2017 | Freezers
2002 Kawasaki ZX-6R is stalling when the clutch is disengaged
Hi, Jesse the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike stalls when clutch is disengaged
zx6r 05 when put in gear engine stalls
Kawasaki 2000 Ninja ZX 6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Nov 03, 2017 | 2002 kawasaki ZX-6R
Frigidaire range GLEF378CSB oven lights come on but the oven does not get warm. Thought I heard a pop
Hello - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately two minutes and turn the range back on. Select a normal bake cycle and if issue continues then the unit may possibly have either a faulty element, bad communication error with the main control board, oven sensor, or mechanical thermostat. I strongly suggest contacting a professional to move forward accurately. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage.
Oct 24, 2012 | Frigidaire FEF366 Electric Kitchen Range
HP Pavilion dv2 laptop running Win7. At boot, white disk activity light starts blinking (as it should) then within ~10secs turns to solid orange. System continues to boot and Win starts up normally, system...
so ,the hDD is busy that it.
windows 7 doing the over 350 updates?
or has virus.
or is the a/v running?
ever heard of task manager.
run that, see whats using CPU processor time.?
control+alt+del = TM
on mine right now, malwarebtyes, is busy, 1%
but at boot is lots more till settles down.
Jun 28, 2017 | HP Computers & Internet
Need to selct english on the ps2 box itself,its in asain can u help
Remove any disk and close the disk tray. Turn off your system and let it sit for a few seconds before turning it back on. Select the "Language" option from the main menu to open the language menu.
Move the cursor up using the directional pad on your controller until you get to "Language Select." Push the X button repeatedly until it lists "ENGLISH." This changes the audio settings from English to Spanish.
Scroll down to the "Subtitles" option in the language menu and change this setting to Spanish as well. The subtitles will appear in ENGLISH at the bottom of the screen every time a character in the game speaks. If you wish, you can skip this step and rely only on the audio settings.
Press the Circle button on your controller to move back to the main menu, which will save the settings. Select the correct time and date setting for your time zone, if the system asks you to do so. Push the Circle button again to access the main menu.
Place a PS2 game into your console and let the game load. You should now have ENGLISH, settings on your PS2, including subtitles.
May 05, 2010 | Sony PlayStation 2 (PS2) Console
Volume control candy oven timer
Switch off the oven, leave for 5 seconds and switch it back on.
Candy Customer Services asked for over £100 to have an engineer sent to my house, which I refuse as I thought the oiven was good.
I had to switch off all the electricity in the kitchen but after this 'reset' the oven turned to the normal 'high' volume.
Jan 12, 2010 | Candy Ovens
Poor sound quality with a infinity sound system.
Remember seing something under one of the seats ,but in my old age it could have been a cd autochanger
Nov 10, 2009 | 1990 Plymouth Voyager
Fridge & Freezer smell like a gas grille...
Do you mean it smells like propane? Or does it smell like propane exhaust (think taxi cab or fork lift)?
Either sounds pretty serious. I have heard of people using hydrocarbons to recharge refrigeration systems, though it is not the recommended method.
Do you own your residence or do you rent? Either way, call a repair man or the management of your rental right away and insist to have it inspected.
Fridges might smell like plastic or stale air if not used in awhile, but not propane/exhaust that I have ever heard of.
Jul 30, 2009 | GE GSH22SGRSS Side by Side Refrigerator
Can't eject cd magazine - E-99 error message
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
