Question about EuroTech EWF272 Extra Large Front Load All-in-One Washer / Dryer
I have a EuroTech EWF272 frontload washing machine. I go thru the procedure, the lights work, but when I push the button to start nothing happens. I once waited ten minutes to see if there was a delay, but still no luck. I know that the door latch had recently been replaced by a tenant. It closes, but I wonder if there may be an electrical problem. Thanks, Bob
  • 641 Answers
SOURCE: tripped my circuit and wont reset or start HELP!!!
Your circuit braker tripped because of a current problem that in your case caused a defective part. Since your machine is still under warranty, best way will be to contact to the appropriate factory service center for repair the problem. Good luck!
Posted on Aug 23, 2007
huuum
  • 750 Answers
SOURCE: EuroTech EWC177 washer/dryer combo reset
tinaheinleHello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, ..well this is a solution.....
my roommate unplugged the machine while it was drying. the start and spin lights were both flashing. I called the company and they told me to reset it, but the weren't sure how, lol.
I unplugged it and waiting, nothing. I flipped the breaker, nothing. I finally turned it to a setting, and turned on nob on the dry, and it started clicking.
I turned off the dry, and hit the start button, and it started right up...
If the next time you use it and it's fine then you did succeed in resetting the system and will be alright!
Let me know that we were successful!
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
MNfisherman
  • 11896 Answers
SOURCE: Manual for Eurotech MLD110
(copy and paste this link in your address bar)
http://www.ersatzteilonlineshop24.de/suche_ger2.php?model=MLD110&hersteller=Eurotech
Posted on Feb 01, 2009
  • 1525 Answers
SOURCE: My daughter was using the
hello, if it's total dead then it could have blown the fuse. it will be a glass type in the washers power supply. that smell could be the motor burnt out. which can cause a short to ground cause the fuse to blow check the belt at the back might have come off or snaped hope it helps
regards
shaun
Posted on Apr 04, 2011
Daniel S
  • 4323 Answers
SOURCE: The washing machine works fine
Hi
The issue is with the door lock assembly that is bad and should be replaced. If the door lock assembly is bad the control will sense that the door is open and so will not start a spin cycle. If you want you can test the door lock assembly with a voltmeter before replacing it. Hope this helps...please post back for further assistance.
Daniel
Posted on May 09, 2011
Tripped my circuit and wont reset or start HELP!!!
Aug 22, 2007 | EuroTech EWC177 Front Load Washer / Dryer
GE spacesaver washer will not start...it clicks when pushed but nothing happens
frontloader, try leaning against door when pressing start . if it works then get door lock switch replaced
Jul 31, 2015 | GE Washing Machines
I have a Eurotech EWF150 frontload washer that does not spin. The drum will turn for rinse and wash cycle, but not spin. We checked the motorboard and there are 2 spots that appears burned. Hubby is trying...
I am not 100% sure your problem is the same as the one i had with my frigidare front loader but my door lock switch went bad. it would wash fine but when it came time to spin it only would tumble.
Jan 02, 2012 | EuroTech EWF150 Front Load Washer
I am after the dimension for the ewf272 front loader washer dryer
The dimensions for the ewf272EL are:
Depth 23.63 in.
Height 33.25 in.
Width 23.38 in.
I hope this helps.
Mar 09, 2011 | EuroTech EWF272 Extra Large Front Load...
The delay start light on my washer is on and I do not want to delay start. I have pushed the cancel button twice like instructions say and once I hit start, the delay start light is on and machine is...
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
Nov 23, 2010 | Frigidaire FTF2140FS Front Load Washer /...
The lights come on, but the machine doesn't start
do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
May 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer drum not rotating
The reason for the washer drum not to rotate is either the belt or the motor. Check the belt. It may be broken or, it may have slipped of the pulley or drive motor. If the belt is fine, replace the motor.
Thank You for using Fixya.com
Aug 02, 2009 | EuroTech EWF272 Extra Large Front Load...
Need help
It may be the control panel board. Replace it you can probably do it yourself and that should solve the problem.
Jan 09, 2008 | EuroTech EWC177 Front Load Washer / Dryer
EuroTech EWF272 Extra Large Front Load All-in-One Washer / Dryer Logo
56 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
