Question about Sport & Outdoor - Others
On a 1997 Yamaha GP1200 Waverunner. On a replacement rebuilt engine the rear cylinder will not fire. The engine was replaced because this same cylinder on the original engine either ran lean or the oiling system did not function properly. The piston and cylinder were destroyed on this cylinder The other two cylinders on the replacement engine will fire and run. All cylinders have good spark. Any suggestions? Thanks, Bill
SOURCE: replacing rear brake pads on a 2006 yamaha raptor 700
open bleeding nipple slightly insert anything flat and push back piston ,lock bleeding nipple put pads in and pump brakes
Posted on Aug 29, 2008
  • 2336 Answers
SOURCE: cylinder head skim
From my understanding, the combustion area of the head should have a diameter that is the same as the cylinder i.e. 56mm. If you took 0.5mm from a standard head, your squish would PROBABLY be Ok, however, you need to measure this. Its quite easy, poke a piece of solder wire in to the cylinder via the spark plug hole and trap it between the piston and the head by gently turning the engine over with the kickstarter by hand. Remove the squashed solder wire and measure with a set of vernier calipers. 0.8mm is about right and as Elf said, anything below this is getting a bit close. Do this for the front, back and left and right of each cylinder. Reducing the squish only has only a moderate effect on the compression ratio and does not require higher octane fule. I did this for mine and it was fine - so you 'should' be Ok.
Posted on Nov 20, 2008
  • 166 Answers
SOURCE: mazda rx 7 rebuilt kit clutch master cylinder.
crack the bleeder nipple on the slave cyl and get some one to slowly push the pedal see if any fluid shoots out if not you may have killed the new seal in the master cyl.
it sounds like you did every thing right its just that old cylinders get were in them and if you don't hone them out and put a new sleeve in them quite often you will rip the new seal apart on the first pump of the pedal.
any way check for presser and let me no
Posted on Dec 21, 2008
roedmondson
  • 68 Answers
SOURCE: 2000 CIVIC System too lean Cylinder 3 and 4 misfire Deteced
  1. P0171: This means that the oxygen sensor has detected a lean air-fuel ratio. This can be caused due to a vaccuum leak or a problem in the HO2S circuit or the HO2S (Heated Oxygen Sensor) itself. (Bank one Sensor one). This is commonly located along the exhaust pipe. It could also be a bad Mass Air Flow sensor or a bad Engine Coolant Temperature sensor. Diagnostic checks will be needed to be carried out to be verified though
  2. Well as for the other codes, it means #3&4 cylinders are misfiring. It is a possibility that the P0171 code mite have caused the others to show up. I can be wrong though. But it is a strong possibility. If the air fuel mixtue is too lean indeed, mis-firing will occur, unless it is an actual electronic and not a mechnical problem. By the way, when these codes appear, how is the engine's performance. Does it remain the same or behaves poorly?
Posted on Feb 14, 2009
  • 5 Answers
SOURCE: 1998 GP1200 yamaha jet ski won't start
When replacing battery in yamaha GP1200 when attach negative cable the unit seems as wants to turn over the engine while the unit is off and no key in place.. also notice in seconds that the battery terminal on negative side started smoking..actually melt the new battery terminal on negative side..yes, postive was connected to positive. Any ideas what why this would take place??
Posted on Aug 16, 2009
Why does the waverunner does not start
You are in the wrong category.
Jun 12, 2013 | Cars & Trucks
Yamaha waverunner does not start
hi there it sounds like the switch gear need pulling apart and the copper contacts cleaned as it sounds like the kill switch is closed up and the starter button contacts need cleaning as well also check to see if the stater soliniod might need a cleanup where the wires go,also check your fuses to see if there contacting alright if you ride in all weather or the bike sits outside it can have these problems as mouisture gets into everything. hope this helps cheers pete
Jun 12, 2013 | Yamaha 98 Gp 1200 Air Box Intake Mount...
Yamaha waverunner
check for corrosion of the engine as leaving it for long any water left in the system will cause problems.
May 26, 2013 | Yamaha XL700Z Waverunner
High idle 1997 gp1200
obviously your fuelling isn't set up correctly
Jul 13, 2012 | Yamaha 98 Gp 1200 Air Box Intake Mount...
1999 Yamaha XL1200 Waverunner starter always turns
i recomend replacing the solinoide !!!
Mar 11, 2012 | Yamaha Boating
YAMAHA WAVERUNNER 2000 XL 800, WILL NOT RUN PAST 12 MPH
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
Apr 05, 2010 | 2003 Yamaha YZ 250
Jul 15, 2009 | Yamaha 12V Air Pump
Sport & Outdoor - Others Logo
151 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
