Need a manual for a C60B 60W Microphone P/A Amplifier 54-5746
    President:
  • 2,777 Answers
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. If you require some other manual, the file doesn't work, or this isn't what you are looking for PLEASE reply to my answer here and I will correct it for you. Here is the manual / guide please give it a few minutes the file is quite large:
http://www.bogen.com/products/pdfs/mixerampspdfs/C35m.pdf
Posted on Oct 15, 2010
How to play my acoustic guitar on my my jbl avr134 home sound system it does have a amplifier I want the steps for it plzz
An acoustic guitar, unless it is an electric type, will need to be played near a microphone in order to provide a signal for the sound system and the microphone or the guitar will have to be connected to a compatible amplifier input.
Impedance matching is not so important unless high quality is required but matching the sensitivity or gain of the input to the output of the source is important for optimum performance.
A moving coil microphone has an output of just a few millivolts and a crystal microphone can produce an output of around one volt.
Aug 10, 2015 | JBL Music
250W, 8 Ohms speakers on 150W, 6-16 Ohms Amplifier.. What is the effect of this?
If your amp states that it will support a range of 6 - 16 ohms, an 8 Ohm speaker will work fine on it. If the speakers you hook up to it are lower than 6 ohms, it may work until you turn it up, then it will either shut down or burn out the finals. If you hook up a speaker that has a higher than 16 ohm, it will not get very loud, and it shouldn't hurt the amp.
Feb 14, 2012 | Concept Car Audio & Video
I got a punch 450.4 car amplifier that a friend gave to me that is stuck in protect mode. he had it pushing two kicker L7 4 ohm dvc subs. is it fixable and if so what would i have to do to fix it?
Capacitors are blown on the output side most likely. That amp isn't made for subwoofers. It will cost about 100 bucks plus shipping to send it to a competent electronics shop that has the ability to to that. If you are handy with a soldering gun, you have open it up and look for blown capacitors and replace them yourself. They sell them all at Radioshack.
Mar 25, 2011 | Rockford Fosgate Punch P450.4 60W x 4 Car...
Can this present amp use microphone? because i need the one with mic input for my project
No, you have to use a mixer or a microphone pre-amplifier.
The inputlevel of those amps are to low for a microphone.
regards,
Gerard
May 07, 2010 | Yamaha P4500 Power Amplifier 2-Channel
How do i use a microphone with the amplifier?
If you mean with no microphone preamp, you'll need a self-amplified mic that supplies Line Level output. It would connect to any input on any standard home audio component except Phono.
For a standard mike, you'll need a mic amp in between the mic and the Yamaha.
May 07, 2010 | Yamaha DSP-A1000 5-Channel Amplifier
I need to know what the wattage the alpine mrv-f407 puts out when its bridged or only running 2 channels?
RMS Continuous Power (at 12.0V)
Per channel into 4 ohms...............40W, 0.08% THD
Per channel into 2 ohms ..............50W, 0.3% THD
Bridged into 4 ohms.....................100W, 0.3% THD
RMS Continuous Power (at 14.4V)
Per channel into 4 ohms...............60W, 0.08% THD
Per channel into 2 ohms...............80W, 0.3% THD
Bridged into 4 ohms.....................160W, 0.3% THD
Max. Power (at 14.4V)
Per channel into 4 Ohms..............120W
Bridged into 4 Ohms....................320W
This should help.
Apr 30, 2010 | Alpine MRV-F407 Car Audio Amplifier
Hi, I have a pair of RF prime 6x9s 60w rms, 48hz
Ok for best results.
1.make sure you agust the gain according to person prefrences.
2make sure you set the crossover on the amp.ok in your speakers the would probley sound best if you set the Low pass fillter at 50hz and the high pass fillter at 25khz (if you have one) or on your headunit
Hope this gets the results you want.
Alex
Nov 28, 2009 | Phoenix Gold XS2300 Car Audio Amplifier
Amplifier Issues
HERE is the manual for your amplifier.
It is listed as being 4ohm STEREO stable Bridged.
Meaning the lowest impedence possible on (2) bridged channels is 4 ohms.
If you have a Dual Voicecoil Subwoofer, chances are - it is wired in parallel - resulting in a 2 ohm load.
This low resistance causes rapid heat buildup, and is causing your amplifier to go into protect mode.
There are many reasons the amplifier is doing it NOW as opposed to the prior vehicle...
If you alternator is not giving your amplifier 14V, it must work harder to produce the same amount of power. WORK = HEAT!
If the head unit is not the same, the signal voltage also has an effect. If the voltage is lower, the amplifier has to work harder to keep up at the same "volume" setting.
In any case, you are over-driving the amplifier, and it is shutting down with its thermal protection circuit.
Either lower the gain on the amplifier, or purchas a mono channel amplifier made to drive subwoofers.
Your Subwoofer is craving power, and you're giving it 60W !!
Thank you for using FiXyA - A FiXyA rating is appreciated.
If you have more questions or need clarification - let me know!
Jan 21, 2009 | JVC AM FM CD DET FACE CAR STEREO
69 people viewed this question
k24674
jasbo
jasbo
