Question about GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White
I have GE PDS22SBPAR SS bottom freezer fridge. it has no ice maker installed, not connected to water. The water leaks from underneath. there is no drain that we can see... there IS NO hole in the bottom of the freezer to pour hot water in. There is no pan under the fridge. no wonder the defrosted stuff leaks out - it has nowhere to go! or did we miss something and the drain is somewhere? HELP.
  • 5568 Answers
SOURCE: GE built in Fridge does not defrost and freezer ices up
Defrosters are commonly controlled by a primitive timer and this may have a 'dry' and a 'wet' (humid) climate setting that will cause the defroster to cycle generally every 12 or 24 hours.
If set wrong (by accident or on purpose), it can allow too much frost to accumulate before attempting to defrost.
This can cause a gradual buildup of ice.
Also the heating element for the freezer may have failed open so it never heats at all. The connections that need to be checked are often buried between the in- and outside walls.
The timer is probably still OK since you apparently aren't having a problem on the refrigerator side.
Posted on Jun 10, 2008
  • 1543 Answers
SOURCE: Water leaking from bottom left freezer/dispenser side
Take the metal back panel off the inside of the freezer, exposing the cooling coils. Below the coils, at the very bottom of the freezer compartment you will find a small drain hole. (Presently covered over with ice) Use hot (not boiling) water and a turkey baster to melt the ice and force hot water into the drain hole until the water runs out the drain hole (and into the defrost drain pan under the refrigerator) on it's own. This should be a Fix-Ya for your refrigerator.
Posted on Dec 25, 2008
  • 1543 Answers
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Posted on Jan 06, 2009
  • 1543 Answers
SOURCE: water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
Posted on Jun 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Posted on Apr 19, 2010
Ice maker leaks on floor when I turn on after awhile
is the water coming from the ice maker for sure?
It could be that you may have clogged defrost drain line and the water has no where else to go but the bottom of freezer..Defrost happens roughly every 8 hr or so...
Jul 11, 2017 | GE Refrigerators
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
I have an old GE fridge with ice maker in freezer, water started leaking and flooded floor of freezer and started leaking outside freezer. What's going on & how do I fix it?
I think you need a new fridge/freezer. Look for offers now on sale some are quite reasonably priced and home Depot has interest free credit.
Sep 19, 2017 | GE Refrigerators
Refrigerator ge profile model TFH27PR water leaking onto floor
Hi this problem could arise due to various reasons so lets find out what could it be the cause.
1)In the back of your freezer compartment is the drain hole. It's very common in GE for the drain to freeze up. With the drain hole plugged up, your freezer will continue to defrost the evaporator, but not the water in the drain hole. So the water builds and freezes, builds and freezes until it eventually overflows into the air diffuser for the fridge causing the leaky fridge problem."Heat Probe" that can be installed.This will prevent water from freezing up in the drain hole allowing it to drain as designed
2)Inspect the door seals and the sides of the refrigerator around the doors. If you see any beads of water or moisture, then the door seals may be failing to create an air tight seal which causes the cold air from the refrigerator to escape and form condensation around the doors. Sometimes you can solve this problem by applying a light film of gasket lubricant to the existing seals or just cleaning them of any debris with a warm soapy rag. If they still don't seal well after you apply lubricant, or clean them, you may need to replace the entire seal assembly.
3) If the water is coming from the freezer but you think that the defrost drain pipe is clear, then it may be coming from the ice maker. Check the ice maker for cracks in the unit's body or a misalignment of the water supply line. Make sure that the water supply spout in the freezer lines up with the ice maker's water supply cup.
4)Check the ice maker copper water supply line, your ice maker water filter, and the plastic ice maker water supply tube for any cracks, splits or connection leaks. If you find any leaks, remove the leaking part and obtain a replacement at the hardware store.
5)Your leaking refrigerator may just have a cracked or damaged drain pan. Your fridge regularly drains water into this pan to prevent water pooling in the fridge itself. Evaporation takes care of the rest. Look underneath your fridge where the drain pan sits and pull it out for inspection. If it has a crack or is otherwise damaged, contact the appropriate retailer about getting a replacement as soon as possible.
6)If your leaking refrigerator is draining inside as opposed to onto your floor, you're probably dealing with a clogged defrost drain. Your fridge is constantly producing condensation inside the freezer, and that condensation drips down the defrost drain into a drain pan underneath the unit. This defrost drain can become clogged with debris or, more often, it freezes shut. Look in your refrigerator manual to locate your defrost drain, and take the appropriate steps to unclog it (inundating your drain with warm water will often do the trick).
Note:Switch you Refrigerators for more than 8 hours and let the frost melt fully use hair dryer and now switch on and check you are getting leak.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 09, 2010 | GE Refrigerators
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Water leaking from underneath fridge
If you have a ice maker inside your freezer, check where the water connects to the back. I think you will find a leaking connection. Tighten connection to fix the leak.
Please rate this solution
Sep 06, 2009 | Frigidaire Refrigerators
Fridge leaks water when Ice maker is activated by lifting lever
Either a loose or broken hose , or worse, a crack on the water valve.Pull fridge and check water valve and hose when signal calls for water.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge with ice maker. Water is slowly leaking
drain is clogh at the bottom of the freezer
Mar 29, 2009 | Refrigerators
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
