Question about Pacific International Pacific Laser PLS180TOOL 180DEG Palm Laser - Self Level w/ Wall Bracket
HOW DO I CALIBRATE A PLS2 PALM LASER? - Pacific International Pacific Laser PLS180TOOL 180DEG Palm Laser - Self Level w/ Wall Bracket
2 Suggested Answers
SOURCE: PLS2 laser level, horizontal line very dim, vertical line ok.
PLS 2 Palm laser; dim horizontal line. vertical line OK
Posted on Nov 12, 2010
Can I repair my pls2 laser level
Would it need a new battery? If so replace at
Jul 11, 2016 | Laser Measuring Tools & Sensors
How do you calibrate a laser distance meter?
Calibrating a laser distance meter is not all that complicated. eHow.com has a really good guide. How to Calibrate Laser Distance Meter eHow
Jan 22, 2014 | Measuring Tools & Sensors
CALIBRATE LASER ALIGNMENT LB4
can you inform how i can calibrate laser level alignment lb 4
Jan 23, 2013 | Leica Laser Alignment Lb-4 Dual Grade...
How do i calibrate a PLS 180 laser
the pls is a pendelum system you need to open it from the rear and shift the weight it is usually a set screw that you turn in or out to change the resting pointof the pendulem
Feb 26, 2010 | Pacific International Pacific Laser...
After hard reset palm unable to calibrate
Perform hard reset after back up your personal data. If issue persists you may disconnect the battery and keep disconnected about 10 minutes and reconnect
Jun 29, 2009 | Palm Tungsten E2 Handheld
Palm ungsten E/E2 digitizer - fragile?
Your gonna find that with the exception of the battery, all else should be left to the factory if nothing else but for factory warrantees. Your probably putting static electricity into the unit and they don't like that.
Dec 29, 2008 | Palm Tungsten E2 Handheld
I have a Palm TX. 3Years old. 6 Months ago had to calibrate Touchscreen every day. 2 months ago had to calibrate touch screen 2/3 times a day. Recently can't calibrate touch screen. Targets go into loop...
Same happened to my 3 month old TX. I just recharged it, and all was OK! Sounds strange at first, but in my hometown, it is very humid, so maybe it got some moist inside and that caused some variations in the power or battery or voltage... dunno, maybe you need some cleaning, or try to calibrate while plugged.
Hope to be useful!
Jul 03, 2008 | Palm TX Handheld
Ps3 laser
hi the problem with this is replacing the laser is the easy part and more or less anybody can do it but to get the new laser to work you need to calibrate it this is what the osciloscope is for it needs to be connected to certain parts of the board and then take readings from the scope as your adjusting the laser you cant do this without it as you can damage the new laser if you get it wrong.
Now you can fit the laser yourself thats the easy part but the scope costs about £1000 or $2000 so more than a new ps3.
If you can buy a working laser out of a damaged ps3 thats over heated then you should find it will work as sonn as you fit it in but new ones need calibrating.
Try this so you get some idea of the procedure with the scope use your search engine and type in:
how to calibrate ps3 laser
or
how to calibrate ps2 laser
this will then bring up loads of sites that show you how its done with the scope.
Its not worth doing it without the scope as you will damage the laser beyond repair but buy the new laser and get someone to fit it and calibrate it for you as that would be the cheapest sollution let me know if you need further assistance ok
Mar 14, 2008 | Sony Playstation 3 (PS3) Console
Pacific International Pacific Laser PLS180TOOL 180DEG Palm Laser - Self Level w/ Wall Bracket Logo
299 people viewed this question
Top Pacific International Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Pacific International Measuring Tool and Sensor Expert? Answer questions, earn points and help others
