Question about Flint & Walling/Star Water # 1/2HP Shall Well Pump
Customers pump has missing wiring diagram and motor needs to be connected 230 volts. Black yellow red green white wires showing. I beleive from the past yellow is line 1 ,black is line 2 red green tie and white is open is this correct? thank you
Need 120 volt wiring diagram for model 113.299410 table saw with model 824370 motor
L1 L2 are the common or line,cord color doesn't mater, green is ground. also should be the ones with screws. try powering the motor for just a few second 2-3 at the most, if it snaps right to life you got it, if it starts slow or not at all, immediately shut it off and check the wiring again. pictures help us fixya guy help u better. there is thousands of different motors
Jay
Jun 03, 2017 | Pool & Spa
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
Wire 230 volt air compressor wiring diagrams
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Feb 11, 2014 | Air Tools & Compressors
Emerson Motor model T55CXCAS-1179 230 volt
There should be a wiring diagram sticker on the motor. If not, let me know at questions@oskopoolnspa.com
Jun 03, 2013 | Emerson Pool & Spa
I have a marathon 3hp motor wired for 220 on a campbell hausfield air compressor. It has a white, black, and green wire coming out of the motor. I am using a no. 12 wire with ground. how do i wire it up to...
Hi! sims146
The Green wire from the electric motor is ground. Check the compressor motor, make sure it is wired for 220-230 Volts. If it has a white wire it could be wired 120 Volts. There should be voltage and current ratings on the motor plate. I always double check these connections. At 230 Volts this motor should be 17 Amps full Load. A 25-30 amp fuses are required to protect this motor circuit. Otherwise up to a 42.5 Amp Inverse Time Delay Breaker could be used.
The welder circuit should have 230 Volts between the Red and Black wires. The white wire is Nutral / Ground. Hopefully this is a 30 to 40 Amp circuit. The Four prong air compressor outlet, White is Neutral, Black and Red 230 Volts, Gray should be ground. Please check with Voltmeter, as some times people swap colors.
InMrFixIt
Jun 25, 2011 | Garden
The compressor is 3HP 230 v motor. In the pressure switch it is wired white and black from motor and green to ground. Is the white and black wire 115 volt each or it the white wire common and black wire...
If the motor is 230 v then it should have three wires, black, red, and green, however if the motor is convertible from 120 to 230v then the wire from the motor may be black, white, and green. Check the motors label to see if it has different wiring configurations. If the motor is 230 v only then the white wire would be the other side of the 230 v circuit, and the pressure switch should break both sides. Neutral is not used. Note that some people would use a single pole pressure switch, although this will work it is not recommended.
May 07, 2011 | Ingersoll Rand Single Stage Electric...
Need to know how to put the wires in the right order on a AO Smith 5.0 56 spa pump red white and black
Red and Black should each be connected to the individual power legs, for 230 V operation. The white wire should be connected to ground.
Nov 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
Rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Flint & Walling/Star Water # 1/2HP Shall Well Pump Logo
94 people viewed this question
Top Flint & Walling/Star Water Garden Experts
Dennis Key
Dennis Key
john h
Are you a Flint & Walling/Star Water Garden Expert? Answer questions, earn points and help others
