Question about EliteGroup 741GX-M Motherboard
New ram I purchased two 1GB Ram strips. After I installed them the PC just keeps re-booting as soon as it goes into windws.
Memory type is the major problem with the 741GX chipset. Very touchy. I used Crucial PC3200 High Density memory to start with (2 x 1 gig Memory), system was lagging even though adjusted settings in bios. whenever a USB device was pluged in, the system would stop responding. Switched to low density memory and no problems since (Ultra PC3200 (2 x 1 gig Memory), and the USB device problem is also solved. I am running WinXP with SP2.
Posted on Jun 02, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Mite be wrong type for your pc mite check internet for type you need if you need ddr or ddr 2 or new ones needs ddr3 or ifit is gateway or toshiba mite need specific kind need to go to internet and check on upgradeing your ram and find if your is compatiable sounds to me like have bought the wrong kind ..... lala linda
Posted on Jun 02, 2008
System not booting after ram upgrade
Sometimes it passes a poorly designed ram test, probably faulty ram, speeds always default to the slower of a pair. Some computers need all slots full. Did you buy it new? We have Re-PC for used components in the Seattle area, a great resource.
Jan 11, 2014 | Intel D102GGC2 Motherboard
Replacing ram (1 x 512mb and 1 x 256) with 2 x 1gb. PC boots ok (slowly) then seems to freeze (nothing shown on taskbar) - desktop icons take ages to appear then seem to randomly refresh. The new ram is...
Try re-installing the two new sticks two or three times. Sometimes there is a little build up of oxides on the contacts on the motherboard and keeps the bios from properly recognizing them.
Sep 18, 2013 | Fujitsu Siemens SCENIC P300 PC Desktop
Upgraded ram 1gb wont boot hp 510 mobo 30C4
If you added another 512Mb RAM to increase the RAM to 1Gb then the new 512Mb memory stick could be incompatible with the original 512Mb or it could be faulty.
Use RAM that is same make and speed as the original RAM.
Remove both RAM and just insert the new 512Mb into your laptop and see if the laptop boots up, if not then the RAM could be faulty.
Mar 02, 2013 | HP 510 Notebook
RK549AA-ABA SR2170NX problem: i think my second slot for ram is no good. i'm supposed to be able to install 2 gb max . I bought 1gb ram to install in slot # 2 but it doesn't work. can i install...
Is the 1Gb RAM you purchase the same make and speed as the original? If not, they may not be compatible with each other or the new RAM module may be faulty.
Try removing the RAM from slot 1 and insert the new 1Gb RAM module in slot and boot up your laptop to test the new 1GB RAM module.
Installing a single 2Gb RAM module should work.
Dec 29, 2010 | Computers & Internet
I am using Intel D865GBF board having Dual Channel DDR400/333/255 SDRAM memory support. It is of 3GHZ, 256 MB RAM. The other day I bought 1GB RAM of Transcend and tried fitting the same. But the PC never...
Yes it can support 1GB ram. Max capacity up to 4GB of ram, meaning 1GB each on each slot. Make sure that the memory that you will be installing are either DDR400, DDR333 or DDR266. It could be the RAM is faulty if the one you bought is the DDR's that I mentioned
Oct 11, 2010 | Intel D865GBF Motherboard
Won't Reboot after installing new RAM
If you remove the 1GB memory that you were trying to install and it will boot, then it is your new memory that is not compatible. Check here for what memory will be compatible with your laptop.
Jan 02, 2009 | Dell Inspiron 6400 Notebook
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
New RAM and Computer won't Boot
Try booting with just one module inserted, then switch to just the other to see if the problem is with one of the new DIMMs. Does it still work fine with the old RAM?
Oct 15, 2008 | Toshiba Satellite M45-S165 Notebook
Installed new RAM, PC would not boot up.
Will the PC boot? It may just be loose. Try it again. The PC may not boot if it does'nt recognize the memory.
Sep 19, 2008 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Apparent conflict between my wireless adapter and RAM
have you tried looking for an updated bios version for your motherboard?
Jan 05, 2008 | Computers & Internet
EliteGroup 741GX-M Motherboard Logo
281 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
