Question about Car Audio & Video
Stereo is stuck on mute unable to get back to sound
  • 400 Answers
Try taking fuse out and wait a few minutes or if its a detachable face remove the faceplate and see if there is a reset button.
Posted on Oct 16, 2010
How can sound be muted on ffcmo934ls a Frigidaire microwave oven?
I appreciate your inquiry, friend!
From what you have described you would like to mute the sound on your Frigidaire microwave, FFCM0934LS. I have researched your microwave and I was unable to any instructions on how to mute your sound. Unfortunately you are unable to perform that operation on your microwave. I hope this is helpful information. -Matt
Mar 03, 2015 | Frigidaire Microwave Ovens
My mercedes e class 54 reg had power down my stereo I change the fuse power came back but it shows mute mode does not give any sound when my engineer put on his computer its works then mute again
Hands free mute is caused by a switch grounding the radio , if you have a hands free kit it is permanently grounding causing MUTE , if it's a short to ground check wiring loom in car always test loom with a multimeter
Nov 27, 2014 | Cars & Trucks
We lost sound on our Sansui TVD2798 even though the speakers work. Mute button has no effect. Using the remote, we can't find any option for sound off or on.
There usually is an option for turning off the internal speakers as part of the TV setup routine...BUT you may have had a failure of the internal audio in your TV. Your Zenith remote might have a MUTE button which turns off TV sound and displays a mute message or the MUTE buttton might have been pressed accidentally and has become stuck
Jan 08, 2013 | Sansui Televison & Video
I've been having this audio issue with my LG 19LG30 for awhile now. Only recently discovering what exactly was going on. My audio would go in and out on some channels. There would be sound then muted for a...
to eliminate the problem just select the mono sound disable the stereo signal.so that your tv sound will be stable.this happens because not all tv stations are broadcasting on stereo signal thats why your tv keep on switching to mono and stereo base on what signal it receives.plus the signal being feed by the cable provider sometimes they are not stable enough to give the stereo signal so better select only the mono sound...tnx hope i helped you..
please rate my help!
Jun 05, 2010 | LG 19LG30 19 in. LCD HDTV
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
My newly installed pioneer dvd player keeps getting stuck on mute
check the telephone mute cable is not grounded to the chasis as that would mute it.
Feb 15, 2010 | Car Audio & Video
I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
Dec 15, 2009 | Kenwood KDC-135 CD Player
AiWa stuck on mute - no sound from subs.
have you tried powering down unit and seeing what happens?
Dec 02, 2009 | Aiwa CDC-X227 CD Player
JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Oct 14, 2009 | JVC Audio Players & Recorders
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
