Question about Sharp Office Equipment & Supplies
Mx-450 fax transaction report reads fail02(0023). What does that mean?
  • 62 Answers
SOURCE: Can't get Fax Confirmation page to print
What model brand name something!!!!!!
Posted on Mar 07, 2008
leroyal
  • 2120 Answers
SOURCE: only transaction report printing no
Somewhere in your fax defaults menus you should see "enable image".
However, some brands don't have that option available.
Posted on Sep 12, 2008
slipnoman
  • 53 Answers
SOURCE: NEED ERROR CODE TRANSLATION
I do not know what the error code means but try this http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
They should be able to fix your problem
Posted on Jan 09, 2009
brett207
  • 231 Answers
SOURCE: Our RX report for our Canon 830i fax machine lists
This error usually means you have a phone line problem.
You need to try to increase your transmission level, or check the line equalization. It could also be a problem with an echo on the phone line.
Posted on Dec 16, 2009
Testimonial: "Thank you!"
SOURCE: How to print FAX transaction report on Canon LC 9500
First you have to lift the panels under the speed dial numbers to expose all of the additional features and setting buttons, Press the REPORT button, then the SET button. This will give you a daily log.
Posted on Aug 03, 2010
Testimonial: "Thanks, that did it!"
Sharp copier mx-m350n
Custom Settings > Key Operator Settings > (enter access code usually 00000) > Image Send Settings > somewhere under this heading is the Fax setting to control transaction reports
Oct 25, 2013 | Sharp Office Equipment & Supplies
HOW DO I PRINT FAX CONFIRMATION REPORTS PLEASE
Touch the [Image Send Settings] key, the [Fax Settings] key, and then the [Fax Default Settings] key to configure the settings.
Go to Transaction Report Print Select
Setting
These settings are used to set the conditions for printing
transaction reports for single transmissions, broadcast
transmissions, receptions, and confidential receptions.
For each type of operation, touch the key of the desired
condition.
May 16, 2011 | Sharp MX-2300N Color Copier
How do I print the fax log?
Follow the steps below to print Fax Logs for already received faxes
  1. Press Setup , and then press 2 . This displays the Print Report menu.
  2. Press the Right arrow button to scroll through the following report types:
    • Fax Report Setup: prints the automatic fax reports as described in Generate reports automatically.
    • Last Transaction: prints details of the last fax transaction.
    • Fax Log: prints a log of approximately the last 30 fax transactions.
    • Speed Dial List: prints a list of programmed speed-dial entries.
    • Self-Test Report: prints a report to assist in diagnosing print and alignment problems.
  3. After the desired report is highlighted, press OK .
Also, Click on the link below for more information about Fax settings on your printer
Fax Settings
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Transaction Report that includes portion of the fax in AR-5127, not only in error - is it possible?
In fax mode, touch the [SPECIAL MODES]
key.
Touch the [TRANSACTION REPORT] key.
If you want the transaction report to print regardless
of whether the transmission succeeds or fails, touch
the [ALWAYS PRINT] key.
Touch [PRINT ORIGINAL IMAGE] checkbox
Touch the outer [OK] key.
Oct 20, 2010 | Sharp AR-M237 Copier
Jul 22, 2010 | Canon LaserClass 9000L Plain Paper Fax
How can I print a transaction report for faxed items
Press SYSTEM SETTINGS
select Admin Password and enter the password as "admin" and OK on both screens
Scroll to LIST PRINT (ADMINISTRATOR)
Select IMAGE SENDING ACTIVITY REPORT and select FAX. This will print out the log up to a maximum of 200 events ( Tx, Rx and failed sendings)
If you want a transaction report printed for each individual transmission:
Enter Admin mode as above
Got IMAGE SEND SETTINGS
FAX SETTINGS
TRANSACTION REPORT PRINT SELECT SETTINGS and select Single Sending / Broadcast etc and PRINT OUT ALL REPORT
Press OK then CA to exit
Feb 18, 2010 | Sharp MX-2700N Color Copier
Eliminate the transaction report
To eliminate the transaction report, perform the following:
  • Press Function button once
  • Press down arrow 3 times
  • Press right arrow > once
  • Press 5 "Never Print"
  • Press "STOP"
This will eliminate ALL transaction reports. There are 5 options for this function.
  1. Always Print
  2. Error/Memory Print (memory errors only)
  3. Send Only (prints only on sent fax)
  4. Error Only (prints only when there's an error encountered)
  5. Never Print (eliminates all transaction report printing)
This should solve your problem. Please post back with any questions and/or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
I want to report all the telephone numbers dialed today. How wil
You can either view, or print the transaction reports. The machine should print out automatically after 32 transactions, or you can print manually. To print out manually after each transacton, from the control panel select "function", 6, 1, set key. Pesssing key 1 will print journal, pressing key 2 will let you view journal. To set the printing of transaction report for all sent faxes, you can get into the fax parameter setting #13, and scroll to your selection using the up (^), or down keys.
Dan
Jan 07, 2009 | Office Equipment & Supplies
Is there a way to mark faxes?
Hi, can you clarify what you mean by marked??? Do you mean a transaction report or marked as read or something like that? Please post back.
Nov 19, 2008 | Lexmark X4270 All-In-One InkJet Printer
Nov 12, 2007 | Sharp AR-F152 Fax
983 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
