Question about HP DeskJet 9300 InkJet Printer
Hp9300 not feeding thick paper - HP DeskJet 9300 InkJet Printer
    Scholar:
  • 126 Answers
Based on the Media weight for a HP Deskjet 9300
The Main Tray can support up to 36 lb bond.
The Manual Tray in the Back can support up to 70 lb bond via a single sheet.
You must check the weight of the thick paper you are using to make sure your using the correct weight.
Posted on Oct 15, 2010
The document feeder keeps feeding multiple pages. How can this be resolved?
This is a common problem with most feeders. The pick up is by two rollers trying to judge the thickness of paper to collect each time, and with differing thicknesses and gloss covering it often cannot get it right. If it happens with new paper direct from a package try turning the paper over as all paper has a direction to feed but it is not marked on the pack!!!! To completely cure the problem you will have to buy an air lift feeder that suctions each sheet individually. A bit dearer though.
Apr 11, 2012 | Samsung SCX4828FN AllInOne Laser Printer
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
I was printing on a A4 thick (invitacion Card)
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Dec 05, 2009 | Epson Stylus Color 600 with GT-5500...
The MX700 will no longer feed from the bottom. It does want to grab the paper but only gets anout 1/8 in and makes a weird noise when trying to continue. Feed from the back is fine. This seems to have...
Ok dont exced the normal paper typeing Like thickness( you need to read your brochure
and check for acceptable thickness and paper class
The bottom is normally a reserve tray for paper
Oct 19, 2009 | Canon MX700 Office All-In-One InkJet...
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
Paper will not feed into printer epson r300 printer It tries but does not feed
This is a common prob of all epson printer. If you use more than 230GSM thickness paper with the printer and use 80 gsm paper next, it wont pick up. This is due to the spring in the back side of the paper picker unit elangated to more thickness and fail to function fully. you can remove the paper pickup unit and change the spring if you have the service manual.
Aug 10, 2009 | Epson Office Equipment & Supplies
Paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Mar 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Thick paper wont print
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed0c16087.jpg
Oct 21, 2008 | Samsung CLP 300 Laser Printer
Paper thickness error not clear
i have a brother DCR375CW and it will not print on card it keeps saying no paper feed , how do i set it for card thnaks
Sep 29, 2008 | Office Equipment & Supplies
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
HP DeskJet 9300 InkJet Printer Logo
169 people viewed this question
Seeker5211
Seeker5211
