Question about Shimano Cycling
I have the flight deck shimano sc-6502. how do i set the clock without effecting my the odometer?
5 Suggested Answers
  • 37 Answers
SOURCE: fine adustment - shimano sora triple flight deck
Go to Parktool.com
Posted on May 22, 2009
  • 1138 Answers
SOURCE: broken shimano 105 flight deck shifter
You may have broken your derailleur cable. Your cable securing bolt on your front derailleur might have worked loose just enough for the cable to get some slack in it so that your derailleur isn't moving. Try completely loosening the cable bolt at your front derailleur. Pull on the cable and click the control to downshift to the inside crank gear . That should remove all the slack from the cable. Worse case scenario is when you pull on the cable it will completely pull out and it has broken at the shifter. You will have to replace it with a new one. If it isn't broken and you can still shift with the cable make sure your limit screw is properly adjusted for the inside crank ring and then pull all the slack out of the cable with the shifter shifted to that gear. Tighten the bolt that holds the cable in place and try the shifter again. It should now shift normally. If it doesn't you will have to take the bike in to have the shifter repaired. These shifters are not easy to repair unless you have the tools, parts and experience. Hope this helps.
Posted on Jun 05, 2009
  • 484 Answers
SOURCE: shimano 105 flight deck diagram?
If this is not the diagram you are looking for, please check techdocs.shimano.com for the proper one.
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/CycleComputer/SI-0045A-001_v1_m56577569830684407.pdf
Posted on Nov 04, 2009
SuperTech-11
  • 1591 Answers
SOURCE: My working Shimano Flight Deck
Probably a bad battery connector.
Try placing a small folded piece of tinfoil on the negative terminal (s)
Posted on Apr 24, 2011
How do I replace shimano ultegra flight deck brake lever hoods?
Here's a video showing you how. They all install and uninstall the same way.
Sep 24, 2015 | Shimano Cycling
Shimano 105 flight deck diagram?
Oct 04, 2009 | Shimano Cycling
Shimano Flight Deck gear shifts not indicating
There is no spring. I just rubbed the contacts with a small pencil eraser. Then I bent the ribbon just a bit upward to give the contacts more pressure.
Aug 26, 2009 | Cycling
I have Shimano Ultegra Flight Deck 20(?) Speed gears on my Giant Bicycle. Do you have a manual for them as I am new to riding and am trying to learn how they work? Thank you
Go to http://www.shimanoservicecentre.co.uk/ and click on Spares and Support tab at top of page. Download service sheets and assembly diagrams.
Apr 20, 2009 | Cycling
Cycling Logo
158 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
