Question about Toshiba Satellite M35X-S163 Notebook
I cant get my toshiba to come on, i replaced with new battery and charger
  • 56 Answers
Change the power code and try
Posted on Oct 15, 2010
My toshiba P205-S6307 battery is not charging when plugged in
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test your toshiba p205 charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Jan 07, 2013 | Microsoft Computers & Internet
My computer says plugged in, not charging
Dead battery. Test battery, try another cord/charger to verify.
Dec 01, 2012 | Toshiba Satellite A135-S4527 Notebook
I replaced my toshiba battery the 4000mAh to a new one 7200mAh 9 cells but it is not charging on windows its only charge when i shutdown the computer but the win 7 shows me that the cable is plugged in but...
The charger that you had for the 4000mAh battery was strong enough to charge and power your laptop at the same time.
Now that you have increased the capacity of the battery you need a charger that is powerfull enough to charge the battery and power your laptop.
You need to purchase a stronger charger/power brick.
Take care!
damnor01
Apr 24, 2011 | Toshiba LiIon 7200mAH 9 Cell Battery
Hi good day the problem with my toshiba camera is that you have to plug it with the charger then thats the time you can take picture,or view the pics after that if i unplug it along with the charger i cant...
It does sound like the battery is the problem. You don't say what model your camera is, so I can't find out what kind of battery it has or how it charges.
Rechargeable batteries don't last forever. They are usually rated for several hundred recharge cycles, but often they fail early. Lithium batteries in particular can fail early if they are allowed to become totally discharged.
Nov 17, 2010 | Toshiba Cameras
Plugged in, not charging toshiba
Turn off computer, take out charger, then try taking the battery out of the laptop (located at the bottom of the laptop) or side then re-insert and turn on laptop and plug charger back in. Hope this works! if not you either need a new charger or new battery, I suggest u find someone with a toshiba charger to test if it is a problem with the charger or your battery! keep me posted! and good luck
Feb 02, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba P105-S6004 Laptop will not charge battery
Motherboard repairs are often poorly done and they are expensive except for the simplest jobs like replacing the DC jack. And new motherboards are also generally very expensive. And cheap way out of this is buying a used battery charger or a used working motherboard. eBay is usually the best place to start. Good luck!
Jan 30, 2009 | Toshiba Satellite P105-S6104 Notebook
Toshiba Laptop A205-S4577 won't start up
If the battery is removed, it should still start up with the charger connected. A lot of laptops develope problems with the jack where the power supply plugs in, from constantly plugging & unplugging the charger. The jack in the back of the computer is probably bad.
Jan 15, 2009 | Toshiba A205-S4577 Notebook
Toshiba M15-S405 Battery Won't Charge
hello,by anoteher charger,you`r capacitor on charger is poor.best solution for you is to by a new charger,that is 100
Mar 03, 2008 | Dell Inspiron B130 Notebook
Toshiba Satellite M35X-S163 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
