Question about HP Deskjet 2360 InkJet Printer
My printer is not printing ..i have install all drivers which it needs but it still not working
    Problem Solver:
  • 12 Answers
Did you update your computer operating system software and then after installing your new drivers for your printer, restart your computer?
Barbara Grey
Posted on Oct 16, 2010
My laptop is connected to my lexmark z2420 printer but whenever i try to print it does not print
you need the proper drivers to be installed. here is a website that will give them to you all you have to do is follow the instructions and the drivers will be installed. after the drivers are installed the printer should work with your laptop.
http://drivers.softpedia.com/get/PRINTER/LEXMARK/Lexmark-Z2420-Printer-Driver-1231.shtml
Jun 30, 2011 | Lexmark Z2420 Printer
Error message from printer properties : Can not print test page. This operation can not be completed. Take note that printer self-test is working and from printing option cleaning cartrige work perfectly....
You need first to do the following:
Check first a different usb cable ( be the case).
Check that the printer is the default printer or you are not printing to a different printer installed in windows
Do driver setup procedure.
Disconnect printer from usb.
Go to 'installed printers' and remove the printer from windows (right click and delete). If you have documents in printer cue you may need to purge documents in cue.
Restart computer (printer disconnected).
Re-install drivers from disk (printer disconnected).
Only connect printer to usb when required by printer install software or after installing software.
If the above did not work the printer can be faulty, in this case usually it shows some dignostic message, like flashing red light etc.
Check also that is not a windows problem, by installing in on a different computer (get a laptop) and printing a test page.
Regards
Apr 15, 2008 | Office Equipment & Supplies
Xerox 5500DN Phaser PCL driver installed and printer and IP recogized with web printing Prints setup and help info from printer panel pefectly Paralell or IP printing from PC Host only dumps hex output...
The printer is printing in hexadecimal the binary data it is getting over the network as it does not recognize the print stream correctly. Likely reason is that the print stream originator which would be a PC trying to print to it is using the wrong driver. Could try connecting the printer directly to the PC in question and installing it as a local printer then trying to print to it directly. If the result is still a hex dump, then the drivers are incorrect. Usually the drivers not only have to be the ones for the printer but also must be tailored for the PCs operating system as well. If you can get the correct drivers for the PC and can get it to print correctly on the Xerox, then the Xerox can be reconnected to the network and re-installed as a network printer (delete the old network printer first) on the PC. During the installation of the network printer on the PC, do a final test print to check.
Mar 18, 2011 | Xerox 5500/DT Laser Printer
My blue ink is not working. I have tried replacing it and cleaning, yet it is still not working.THANKS
Issues in color printer are many. The most common one is the non-printing of color prints. This issue might be due to corrupted or incompatible drivers in your printer. When the driver installed in a color printer is corrupted or not installed correctly it might lead to issues. So in order to solve this issue you need to install or replace the corrupted driver with a new powerful driver; or reinstall the driver since the issue might be due to wrong installation of drivers.
Jan 19, 2011 | Canon I960 InkJet Photo Printer
Epson printer not working with Core 2 Duo
printing with the processor type and speed has nothing to do with printing capabilities, you need a driver that rightly correspond to your Operating system, say Vista, Windows XP, or Win 7
kindly check this area, and install the appropriate driver.
hope this helps
Jan 08, 2010 | Epson FX 1170 Matrix Printer
Wingdings prints on Brother HL2170W
When printing using Terminal Server, the print driver needs to be installed on the server itself. If you have a printer that doesn't have the driver installed on the server, it will either not print at all or it will use the "fallback driver", which is something set by the person who administers the server. Thus, it may be trying to use an HP driver to print to a Brother printer, which won't work. Ask the administrator to install the Brother driver on the server and it should work at that point.
Feb 26, 2009 | Brother HL 5250DN Laser Printer
Dell 1600n All-In-One Slow Printing
Most times the PCL driver will work just fine for printing .pdf documents. Occasionally you will need to us a PS driver to print .dpf docutments. PCL was designed to work best with MS Word, Excel, etc programs and PS drivers were designed to work best with Adobe .pdf.
One way to see if you have the PS driver already installed, is to (in Windows XP) start>control panel>printers and faxes>in here look for an Icon that represents your printer that has PS in place of the PCL. If this is installed then when you go to print your docuement, choose this icon to print with.
If you do not have the PS driver already installed, try adding the printer to your system. You would do this by (Windows XP) start>control panel>printers and faxes>add a printer wizard>Next>Choose your connection(local or network)>Next>Select a printer port>Next>Install Printer Software(If you have downloaded the most recent drivers, choose have disk and navigate to where you saved it. If you have the CD, use have disk and navigate on the CD to where the PS driver is>Next>You may or may not get the next window asking you to choose whick model of printer you are installing, it varies from printer to printer. From here it is pretty straight foward, just read the wizard and click next. The last step you will need to click finish for the drivers to actually install.
As a side note, not all printers have a PS driver available.
Feb 23, 2009 | Dell 1600n All-In-One Laser Printer
5652 and Vista - duplex print not working
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Feb 19, 2008 | HP DeskJet 5652 InkJet Printer
Teac p11 will not print goes through the motions. cleaned head changed cartridge still not printing
First think to do :
Assure that your printer is the default one and the driver is active
After :
Assure your firewall allow the printer software
After :
Verify your cable by trying a new one
After :
Unplug your printer to your computer
Uninstall the printer driver
Restart your computer without the printer plug in
Plug your printer
Leave Windows install the driver by itself
If it cannot
Assure that you have no printer driver install, if yes, uninstall it
Install the printer driver with your CD
Assure the driver is active
Assure the printer is the default one
Dec 01, 2007 | Teac P11/KIT Thermal Printer
HP Deskjet 2360 InkJet Printer Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
