Question about NEC MultiSync 1550V 15" LCD Monitor
Problem with an NEC MultiSync 1550V 15" LCD
When the monitor is switched on the power button will glow green, and then it will turn off and the screen will flash white. After the same interval the power light will glow green again, but the monitor will still be black, and the cycle will repeat
  • Pinnman59 Jul 26, 2008
    i have the exact same problem same monitor. i also have 35 years experience repairing consumer electronics. It appears to be a PS problem; when the power is removed from the raster board the green light functions correctly turning amber when no signal. however i haven't yet test the transistors related to the switching function of the power supply operation.
  • NEC Master
  • 1,689 Answers
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Posted on Jun 03, 2008
Why does a monitoring keep going off?
you forgot to say, screen dark? and power light off.
does the OSD work? Push button that pops up the OSD screen for bightness, does that work>
\can be one of 4 things. 100 % dead.
try it on another PC>
bad power cord
bad video cable.
bad LCD
bad PC, bad Video card in PC or some game using an illegal video card mode.
try another PC and see if the LCD works there.
easy huh?
Sep 30, 2013 | NEC MultiSync 1550V 15" LCD Monitor
No picture. flashing green light. I can see a flahing, faded image at times.
this sounds like the lcd inverter inside the monitor is going bad. You can take it in to a repair shop and see if they can fix it but with the labor and parts it might be cheaper to go out and buy a new monitor for cheap especially since black friday is coming up you should be able to get a great deal on one. And it will have a warranty.
Best of luck..
Nov 18, 2010 | NEC MultiSync 1550V 15" LCD Monitor
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years):
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
No picture and ligh just plinks
kathleen2002, If no picture, then do flashlight test! Six words and no punctuation will not garner much help on fixya here darlin. Tell us more. We need to know how old the unit is and or number of hours use. Did unit work perfectly the day before? Does this monitor get power from a "black lay on floor brick" or does it power up direct from wall outlet? When it worked last, did it have a bright, crisp image displayed on the LCD panel? If you are not a technician familiar with LC display technology you will NOT be able to repair it. As a consumer/user, your options are very limited. 1. NEC warranty if covered. 2. Cash+old monitor swapout with NEC for a refurbished 1550V w/new CCFT/inverter/SMPS. 3. Local Technician to refurbish your unit with new cold-cathode-fluorescent-tubes+Inverter supply repair if required and test unit's switch-mode-power-supply. 4. OR just trade up to a new and younger model. Bye for now. louie12fix on fixya or lmistyrel
Sep 25, 2009 | NEC MultiSync LCD1550V 15" LCD Monitor
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
Monitor does not wake up.
Check the inverter and backlight bulbs.
Mar 27, 2009 | NEC MultiSync LCD1550VM 15" LCD Monitor
My MultiSync LCD1810 Monitor stays on only for only 1 Second.
The Capacitor on the Inverter Circuit Board has gone bad and needs to be replaced. That's it.
Feb 17, 2009 | NEC MultiSync LCD1810X 18.1" LCD Monitor
No power
The NEC LCD1550M series flat panels that won't or intermittently start up often have a weak capacitor in the power supply. C807, 100uf @ 25vdc electrolytic. Replacing it often restores normal function.
Monitor Mike
Sep 12, 2007 | NEC MultiSync LCD1550M (White) 15" LCD...
Computers & Internet Logo
636 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
