I have an Armstrong Air Ultra V Tech 91 Furnace. I turned heat on and nothing happens. Green indicator light is solid. Heat had already been on a few weeks ago and worked fine. We then had a heat wave and switched to air conditioning which worked fine. Both were off for awhile and now heat isn't working.
5 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: armstrong v tech 91 furnace.
These furnaces goes thru 4--steps for complete run time.... step-1, the small draft inducer blower motor blows and prove thru the small air tube that sucks a switch close to tell the circuit board to go to step-2......the glow plug glows for 15 seconds and step 3 the gas valve opens and dump gas in the venturi tubes and lights off the glow plug and proves thru a flame sensor (pin with 1 electrical wire connection) on the last venturi tube which tells the circuit board to go to the last step 4--, to turn on the main blower fan after 90 seconds!. Where ever it stops at then thats where your problem is!
Posted on Sep 13, 2008
  • 306 Answers
SOURCE: armstrong air tech 91 furnace problem
Sounds like the flue is plugged, I had same problem and opened up the draft fan and there was a dead bird restricting the flue. Furnace will never light if the pressure switch never closes as you have found out. Also has anyone moved the switch some are position sensitive meaning have to be in same position factory set the switch. I had one like that also switch was little crooked so I straighten it up and walla worked.
Posted on Nov 23, 2008
  • 306 Answers
SOURCE: armstrong ultra sx 80 furnace
Flame sensor could be dirty. It is located right beside the last burner looks like a thick piece of wire. Take steel wool and gently clean the probe 4 or 5 strokes is all it will take to take off the carbon build up off. Lets eliminate this item and see if it clears up okay. ken
Posted on Dec 21, 2008
  • 306 Answers
You have a dirty flame sensor. Look at the very last burner and you will see a wire going to a ceramic sensor and it looks like a thick wire. Take some steel wool or fine sandpaper and clean the surface off and it will work like a champ.
Let me know how it goes ken
Posted on Apr 15, 2009
The emergency heat will not turn on in my system. I also noticed the emergency heat light does not turn illuminate on the Honeywell HZ322 TrueZone Panel even if the emergency heat button is pressed. The...
Yes, I believe you are correct concerning the circuit panel.
Regarding your heat pump not keeping up ...depending on what part of the country you live in, heat pumps are not the best thing to heat with. As you probably already know, once it reaches 32 degrees outside, the heat pump stops working and the electric furnace or heat strips come on to supply warm air. Frankly, when that happens, it's like turning on your kitchen toaster and blowing air across it with an electric fan. Doesn't sound to efficient does it. Plus, your electric meter is spinning like crazy and the power company is falling in love with you.
In my area (Virginia) most new home construction is now using what's called a dual fuel system. It's a heat pump, but it has a gas furnace backup for when it reaches 35 degrees outdoors. It's very, very efficient and a very comfortable heat. The gas furnace can run on either Natural Gas or Propane Gas.
In most cases this can be added to an existing heat pump system. The only thing necessary is the Gas Furnace, since you already have a heat pump and all the duct work. Could probably be added for a whole lot less than you''d expect.
The other option is to add a vent-free gas fireplace or vent-free gas logs, if you have an existing solid fuel burning fireplace. They are great for zone heating and/or supplemental heating. Plus, if you have a power outage in the middle of the winter, they'll still work, as they don't require any electricity.
I didn't mean to run own, but I hope all this helps you solve your heating problem.
Please let me know.
Rich
Feb 09, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have an armstrong air ultra v, the ignitor switch or the blower won't come on, we ran the tank pretty low last year, so i'm not sure if we ran out, but we just filled our tank' any suggestions because...
First make sure that your thermostat is turned to heat and auto settings. Then turn up t-stat to where it should be calling for heat.If nothing happens then make sure you have power to heater, gas valve is turned on and blower compartment door is securely latched. If still nothing turn t-stat to fan on and the blower should come on and run until you shut it off. If it does this then you know that you have power to furnace and that the blower works.After you are sure that you have power then remove thermostat cover from base. If stat wires are connected to front of base then disconnect red and white wires and temporairly touch them together. This should send power to your furnace and start the ingnition cycle. If this works then replace thermostat. The sequence of events in the ignition cycle are t-stat calls for heat, induced draft motor comes on and runs for about 20 seconds,then ignitor comes on and lights pilot,then burner lights for 1-2 mins and then blower comes on. I would start at the t-stst and work my way through it. If I can be of any help please ask. Thank you
Nov 28, 2010 | Ruud UBHC Air Conditioner
I got a free armstrong ultra iii 80 lp downflow furnace and would like to install it in my garage but to make more room can i install it horizontally?
If it has an induction fan it will pull the flames through the heat exchanger however you put ... be sure to vent it properly to the outside.
Jul 10, 2010 | Heating & Cooling
Gas Armstrong Ultra V Tech 91-Is green light supposed to flash?
Installed a new filter and furnace is running great now. The old filter was not that old, but we have been doing some remodeling and I figure that is what clogged it so fast.
Jan 10, 2010 | Armstrong H 67 1PH Bf In Line Circulator...
Armstrong air tech 91 furnace problem
Nov 23, 2008 | Heating & Cooling
Armstrong v tech 91 furnace. will not make heat. when on unit runs continuosly no matter what thermistat is set at. could mother board be bad,replaced once already. cah this be done by the home owner to...
Sep 12, 2008 | Heating & Cooling
Heating & Cooling Logo
1,100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
