My compaq presario cq62 won't connect to the internet anymore. It was working fine, and then one day it just stopped. I already tried uninstalling and reinstalling the wireless router (asus rt-n10), turning them both off and on, resetting the router, and plugging the laptop directly into the LAN and WAN. Still nothing. The internet on my desktop works just fine, but my laptop is just about useless if I can't get on the internet. Any advice on fixing this will be helpful.
sandrew
  • 2961 Answers
SOURCE: exactly ASUS WL-500g, no internet connection
My advice and personal experiences with both wired and wireless connectivity, is if you wish to share files and internet connection, purchase a combined Modem/Router and not a seperate router to work along side your original modem. Your modem will send your router an ip address in turn your pc is sent one from your router and can get complicated; keep it simple! These are much easier to set up and control as one unit and if there are ever any connection problems you will know it's either a setting or a modem/router problem and not have to wonder ; is it the modem?; Router? settings? etc. As there are frequent loss of connections both internet and LAN it makes sense have one peice of equipment to maintain.
Posted on Dec 22, 2006
  • 14 Answers
SOURCE: Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Posted on Dec 06, 2007
dante777
  • 623 Answers
SOURCE: Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
Posted on Jan 27, 2009
  • 148 Answers
SOURCE: Hello. I've got a SMC
Sounds defective. Disconnect it, flip it over and give it a smell. If you smell burnt wires or plastic (typically a faint smell, but a smell nonetheless) the router's toast.
Posted on Mar 04, 2009
  • 4 Answers
SOURCE: Laptop Cannot Find Home Wireless Network
Try logging into the router with your desktop hard-wired and find the 25-digit passcode and use that to log on to the wireless network with the laptop. If not, then check if connection is good by hard-wiring the router to the laptop. Let me know what happens or if you have solved the problem.
Posted on Mar 23, 2009
How can I make my Compaq Presario CQ62-112TU laptop a wifi hotspot?
Possibly not compatible witht the software you are trying to run.
Aug 01, 2014 | Compaq Presario CQ62-112TU
Ps3 connect
The PS3 comes standard with WIFI unless your don't have a wireless home hub then your only other option is wired.
but back to WIFI, navigate thought your settings on your PS3 until you come to networking, find the wireless option and insert the wireless key.
it should now connect, to use the PlayStation store you will need to create a PlayStation account.
Dec 20, 2013 | Compaq Presario CQ62-112TU
Compaq presario cq62 won't start but the caps lock led blinks continuously and the wifi led remains on continuously, tried new cpu, worked for a while and started same problem again.
those are blink codes, learn to count them.
if you pulled the CPU i bet you that you used the wrong heat sink compound.
The CPU shuts off all by itself if too hot. your job is to get the fan working and the heat sink working and that thermal compound right.
hp.com
as the blink codes we are not HP here, ever
https://support.hp.com/us-en/document/c02222922
Jun 01, 2017 | Compaq Presario CQ62-209WM
Compaq presario cq62-413nr screen is black and won't show on external monitor
We had this problem several times, even sent it back for service when it was under service plan. It was fine on arrival for service. The "non-techie" solution we came up with... pop the battery... the key series in the book doesn't work, hard reboot doesn't work...unplug doesn't work... the only thing they did during the shipping process was removed the battery so we tried that and it seems to work every time.
Jan 30, 2013 | Compaq Presario CQ62-215DX Laptop
I need a boot disk for my Compaq Presario CQ62-228DX
Go into your device manager, find the missing hardware, right-click, Properties. Hit the "Details" tab & in the Properties dropbox select "Hardware ID" & do a google search on it. If you want to share it here I can help, but this should help you find the right driver, if it still simply won't install then it might be bad. Just go buy you a usb wireless adapter.
Jul 24, 2012 | Compaq Presario CQ62228DX 156 Black...
How o i connect my compaq presario 62-231 NR notebook to wireless network
might find this manual to be of some assistance in setting up that wireless
click here please
May 16, 2012 | Compaq Presario CQ62-215DX Laptop
Why won't laptop connect to wireless internet? Wifi is working, another computer in home is fine
are you at home or Starbuck? location matters.
so, the compaq must be setup correctly.
your router broadcasts the SSID name seen by you on all devices, see that on the Compaq (y/n)
then you must pick wep. or wpa, or wpa2 encyption mode.
as set in your router, we cant see inside you router only you can
then set the passphrase to what you router wants.
is this XP, windows
does the wifi chip look ok in device manager?
Is XP infected.? with malware as all are now.
never post about computers lacking what operating system you have, or answers will be wrong, even all answers.
Feb 12, 2018 | Compaq Presario CQ62-215DX Laptop
Bought a new comp woith windows 7, when i try to watch t.v. it keeps buffering, can u help me tyvm
First check to see that you have known good bandwidth on your internet connection. If this is slow, you will always run into a situation where your playback is running faster than your download rate and causing your streaming software to pause and buffer content before continuing.
I'm assuming you connect to the internet via wi-fi, try connecting to the internet through a cable & see if that helps.
Unfortunately the Presario CQ62-215DX does have problems with poor video streaming capabilities (frequent freezes) and poor wi-fi performance which is probably the cause of your buffering problem.
Hope this is of some help. ;)
Feb 02, 2011 | Compaq Presario CQ62-215DX Laptop
Computers & Internet Logo
505 people viewed this question
David Payne
David Payne
