Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I purchased a used wood splitter with 6.5 horsepower engine. I thought I had the problem solved in starting it when I found intake manifold gasket damaged. However it still boggs down when running for a short time. Runs better if cold and longer before it losses power. Shut it off and it starts fine, then boggs down with in a few seconds. Carburator and plug have been replaced. I noticed the exhaust valve clearence over spec limits. Do you have to take it apart to adjust the tappet? Engine was built in 08, a 120000 series. Also the oil has been changed since it looked more like light grease. Could there also be something internal wrong? Thanks, Dave Watters
  • 4,336 Answers
This sounds more like fuel flow issue to me. Fasten an external fuel supply, bypass existing filter, (use another) and see what the results are.
Fuel sometimes gels and gums up at fittings and filters.
Another test is to pull the fuel hose at the carb inlet, after the condition happens and observe fuel volume.
Posted on Oct 15, 2010
Replace intake manifold gasket; 4.3L V-6
do you have a coolant leak or oil leak. ive always discarded the rubber gaskets provided in gasket kit, and instead, ran a good thick bead of silicone. The rubber gaskets, ive found, can be pushed out, either when setting intake on engine, or if the engine has a bad pcv valve, pressure within block can blow them out. make sure and check pcv valve. after the new intake gaskets are placed on the head, dab a bit more on the 4 corner nubs of the gaskets. i like to use an anearobic sealer around the coolant ports, just thin layer on both sides of gasket. hope this helps. James White, White Auto, Hopkins Mo. 17 yr ASE tech.
Sep 29, 2012 | 1989 Chevrolet S-10 Blazer
How to fix oil leaks in chevy ss impala 1996
Instructions
1. Removal
Unscrew the bolt that holds the negative connection to the Impala's battery. Set this bolt aside for later use.
Remove the engine cover to access the intake manifold and manifold gasket. Disconnect the throttle body inlet duct from the engine.
Twist off the radiator cap to allow draining of the coolant to flow more smoothly. Place an empty container beneath the radiator's drain plug, and remove this plug. Allow all of the engine coolant to drain into the empty container. Replace the drain plug once you are finished.
Tag all of the electrical wiring and hoses before removing so that reconnection is precise to factory settings. Remove these parts, individually, from the intake manifold.
Loosen the bolts that hold the intake manifold to the Impala's engine block. Lift the intake manifold from the block once all bolts have been completely removed.
Use the flat-head screwdriver to pry the old intake manifold gasket from the engine block. Discard this part once you have removed it.
Clean the engine block thoroughly with the engine degreaser and linen cloth. If necessary, use a gasket scraper to remove excess buildup and grime.
2. Installation
  • Coat the top and bottom of the new intake manifold gasket with a chemical sealer so that it bonds to the engine block securely. Position this new manifold gasket so that it lines up perfectly with the cylinder ports of the Impala's engine block.
Place the old intake manifold on top of the newly-installed manifold gasket until it aligns with all of the holes of the cylinder flanges and manifold gasket.
Attach all of the bolts with your hand to the manifold. Once all bolts have been positioned, use a torque wrench and apply 15 foot-pounds of pressure to the bolts to secure the manifold into place.
Reconnect all of the necessary hoses and electrical wiring to the intake. Pour the engine coolant back into the radiator.
Reattach the engine cover on top of the intake manifold and engine block. Start the Impala's engine and check for any leaks around the new intake manifold gasket.
Jul 08, 2012 | 1996 Chevrolet Impala SS
I have a 02 Chevy tahoe....it sounds like coolant rushing throughout the engine while sitting at an idle and about every 2 or 3 days I gotta add coolant its not much also the low coolant light comes on...
I would perform a coolant pressure test because these engines are known for leaking intake manifold gaskets.Check and see if your oil is starting to turn a creamy tan color.
Jan 24, 2012 | 2002 Chevrolet Tahoe
I have a 99 olds 88 LS with a 3.8 and one day when leaving work I noticed white smoke out of the exhaust which turned out to be steam. I have removed the intake top half and found antifreeze all over this...
Yes, I think that is exactly the problem. This engine is known for bad original equipment lower manifold gaskets (use a fel-pro set) and for those upper manifolds to go bad, and especially there is an EGR tube in that upper manifold that you will probably need to replace.
I have seen this a lot on a forum for Buicks (same engine as your olds), and a lot of help can be found there or at an Oldsmobile forum. Probably lots of videos on you tube regarding this engine and how to replace the upper and lower intake gaskets, and that troublesome egr tube. This is well known- you will not have to mess with the heads anymore, just the intake manifolds.
May 01, 2017 | 1999 Oldsmobile 88
After my truck (2003 S10, 4.3) sits after running it for a bit, start it and it will start missing and the check engine light comes on. The miss will go away after about 5 minutes running and the light...
intake manifold gasket. when it leaks water will enter a cylinder causing the sprark plug to short out. when the engine gets hot enough the water will cook off in the cylinder allowing spark to take place. 80% chance intake manifold gasket, buy the upgraded part. 20% chance head gasket. Take the intake off and check for broken intake manifold gasket then buy parts.
Sep 10, 2010 | 2003 Chevrolet S-10
2000 cadilac deville dts started with a missfire on cileder 3. I changed the plugs, boots, coil pack, fuel filter. car ran better still has a miss when i am in gear with my foot on the brake. I found that...
is there a check engine light on? did you change the spark plug wires?
you may have a intake gasket leak or possibly a cracked intake manifold. there is a simple test to try to determine if there is a leak in the intake but it can be potentially hazzardous. with a can of carberator cleaner, spray around the intake gasket and manifold. if the engine revs up, there is a leak. you can also purchase a vacuum gauge and test the amount of vavuum the engine makes. typically 17-22 hg. connect the gauge to a main vacuum port such as the hose to the brake vacuum booster
Apr 10, 2010 | 2000 Cadillac DeVille
Intake manifold gasket / replace
3.8L Engine
NOTE The 3.8L (VIN K) non-supercharged engine uses a two-piece intake manifold consisting of an upper air plenum which mounts the throttle body and a lower intake manifold assembly which houses the fuel injectors. The 3.8L (VIN 1) supercharged engine uses a similar lower intake manifold. The supercharger serves as the upper manifold.
Lower Manifold
NOTE Two bolts which fasten the lower intake manifold to the cylinder head are accessible only after the upper intake manifold is removed. These bolts are located in the right front and left rear corners of the lower intake manifold. Remove the upper intake manifold to service the lower intake.
The 3.8L (VIN 1) supercharged engine uses a manifold similar to the 3.8L (VIN K), but the supercharger serves as the upper manifold.
  1. Disconnect the negative battery cable.
  2. On 3.8L (VIN 1) engines, remove the supercharger assembly. Please see the procedure in this section.
  3. Remove the upper intake manifold using the procedure above.
  4. Remove the EGR outlet pipe from the intake manifold.
  5. Detach the engine coolant temperature sensor wiring harness from the sensor.
  6. Remove the lower intake manifold bolts and carefully lift off the manifold.
To install:
0900c15280269f1b.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Lower intake manifold bolt torque sequence-3.8L (VIN K) engine
  1. Clean all parts well with degreaser, especially the gasket seal surfaces on the upper and lower manifold pieces and between the lower manifold and the cylinder heads..
  2. Install new gaskets to the cylinder heads and new seals to the engine block. Carefully lower the manifold into place. Apply thread-locking compound to the bolt threads. Make sure to install the two hidden bolts in the lower intake manifold. Hand start all bolts, then torque evenly to 11 ft. lbs. (15 Nm). Follow the toque sequence, starting in the center, then working outwards in a circle.
  3. Install the remaining components in the reverse order of the removal process.
Upper Intake Manifold (Plenum)
  3. Tag for identification, then remove the right side spark plug wires.
  4. Disconnect the ignition wires from the fuel rail.
  5. Remove the fuel rail. Please see Section 5.
  6. Remove the cable bracket from the intake manifold.
  7. Remove the throttle body.
NOTE Two bolts which fasten the lower intake manifold to the cylinder head are accessible are accessible only after the upper intake manifold is removed. These bolts are located in the right front and left rear corners of the lower intake manifold.
  1. Remove the upper intake manifold bolts and carefully lift the upper intake manifold from the engine.
0900c15280269f1c.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Upper intake manifold and bolt torque sequence-3.8L (VIN K) engine
To install:
  1. Clean all parts well with degreaser, especially the gasket seal surfaces on the upper and lower manifold pieces.
  2. Install new gaskets to the cylinder heads and new seals to the engine block. Carefully lower the manifold into place. Make sure to install the two hidden bolts in the lower intake manifold. Hand start all bolts, then torque evenly to 89 inch lbs. (10 Nm). Follow the torque sequence, starting in the center, then working outwards in a circle.
Sep 11, 2009 | 1999 Buick Regal
Thanks to all the responses I really do appreciate it. To answer to those who have responded. Yes the dexcool to water mix in the system is 50/50. The temp guage itself was my next thought as well. So I...
Hello Taz..might check the converter to make sure the exhaust system does not have excessive backpressure. Also make sure the electronic cooling fans are cycling...they should kick in and out. They are tied into the A/C system circuit with a relay.
The 3.1L and 3.4L V-6 Engine (VINs J, E - RPOs LG8, LA1) were known to have intake gasket failure. This was due to a bad gasket that was designed by GM...it had nylon in it...Over 400,000 of these were sold in Canada alone. The gasket has since been redesigned and torque specs recalculated. If you replace the manifold gaskets follow these guidelines.
Install a new design intake manifold gasket. The material used in the gasket has been changed in order to improve the sealing qualities of the gasket. When replacing the gasket, the intake manifold bolts must also be replaced and torqued to a revised specification. The new bolts will come with a pre-applied threadlocker on them.
Notice
An oil leak may result if the vertical bolts are not tightened before the diagonal bolts.
Diagonal bolts may require a crows foot to tighten.
Tighten
1. Tighten the vertical lower intake manifold bolts (1) to 7 N.m (62 lb in).
2. Tighten the diagonal lower intake manifold bolts (2) to 7 N.m (62 lb in).
3. Tighten the vertical lower intake manifold bolts (1) to 13 N.m (115 lb in).
4. Tighten the diagonal lower intake manifold bolts (2) to 25 N.m (18 lb ft).
Good luck...i hope this helps.
Jul 27, 2009 | 1999 Oldsmobile Cutlass
Intake minifold removal
First, make sure you are 100% sure of having all bolts removed. Use a small mirror and flashlight if needed to check around all edges - 360 degrees. If there are hard to reach/see places, triple check those.
Once you're sure, it's probably just that the pressure and heat almost fuses the parts together, so some effort is required. Try using a rubber mallet or a small block of wood and a hammer, so that nothing too hard hits the manifold. Try tapping the manifold from the sides in the direction of sliding it across the face of the engine, not pounding it down onto the engine.
Don't hit it too hard, just lots of light taps to slowly break the seal between the manifold, gasket, and head.
Jun 30, 2009 | 1991 Geo Tracker
2002 GMC Yukon Problem
do you have any engine lights on?if so have it tested with a code tester.it should tell you the trouble codes and what they mean.it may be the throttle positioning sensor.
Jan 09, 2009 | 2002 GMC Yukon XL
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
231 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
