Question about Lexmark T642 Laser Printer
Error 900.44 .... RIP Software - Lexmark T642 Laser Printer
    Scholar:
  • 126 Answers
The error relates to the system board / formatter.
R.I.P = Rest in Peace
Turn off machine for 10 minutes.
If error persists follow theses steps:
1. ) If the machine is networked disconnect the cable and power cycle. If the error doesn't come back up swap the network cable, with a good one.
2.) Firmware upgrade
3.) Replace the system board
Based on my experience it's either the network cable or the system board.
Posted on Oct 15, 2010
SOURCE: 900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
Posted on May 24, 2009
SOURCE: 900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
Posted on May 04, 2009
SOURCE: 910 service engine + 900 service RIP software
931 service
Posted on Jul 09, 2009
  • 8 Answers
SOURCE: lexmark T520 I get an error code 900 service RIP
Typically the engine controller circuit cards go bad. the firmware (software) get corrupted. you can try upgrading the firmware but ordinarly you cant clear the 900 service fault to try that. So your only solution is the replace the engine circuit card.
Posted on Dec 22, 2009
  • 217 Answers
SOURCE: 900 service rip software error
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
Posted on Apr 08, 2010
I got message (900.00 service rip software) on my lexmark T644 printer. What does this mean
900 rip is a inrecoverable software error POR printer take data cable out and POR should clear if not then system bord needs replacing more likley corupt dat sent to printer
Sep 16, 2011 | Lexmark T644 Laser Printer
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Erro code "900.00 service RIP Soft ware. What is this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what I foudn working on the same problem....
Lexmark C510 not printing - message 900 service RIP software
Hi, This error could be due to several things, the most common one is that whatever is being sent from the computer is not being recognized by the printer causing the 900 Rip Soft Error. You can try to reset the printer and try sending the print job again. If the error persisted. Then the problem could be a hardware problem with the System Board.
Jan 13, 2010 | Lexmark C510 Laser Printer
Rip software code 900
Please contact the IBM Printer Technical Support for more exact information.
A 900 RIP error means that you have a down-level firmware build on the printer. Its a software bug that was more than likely fixed in later issues of code.
Normally all you have to do is download the newest firmware build and then follow the instructions to upgrade the printer.
Don
Nov 23, 2009 | IBM Infoprint 1612 Express Printer
Lockups and 900.00 Service RIP software errors on C534N printers.
are these printers hooked to surge protectors? 900 rip error is a software communications error and can be caused by any pcb in the printer. any surge, lightning strike,ect can cause the nvram chips to have problems these errors can be intermitten or continuious depending on the damge to the nvram. have you tried isolating any of these to see if it still has the problem off the network?
Jul 15, 2009 | Lexmark C534N Printer
Rca mp3 easy rip software will not load
If you are running windows vista or XP, try running the easyrip installer as an administrator. To do this, right click the installer program file, and choose "run as administrator" (third one from the top).
Hope that helps.
Jul 10, 2009 | RCA M4208 MP3 Player
NO ERRORS......
May 24, 2009 | Lexmark C750n Laser Printer
May 04, 2009 | Dell Office Equipment & Supplies
Lexmark T642 Laser Printer Logo
1,852 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
