Question about Dryers
The machine starts usually with a normal running sound then it begins to squeak and sometimes there is a loud screeching and banging that comes from within. I took the machine apart and looked in from the top, front and bottom and found nothing hanging that could cause the banging sound, the belt is connected but there is a slight squeaking sound coming from it when I pull on the belt. Maybe the drum is hitting something. What are your thoughts?
    Sergeant:
    Champion:
  • 226 Answers
Try some 3 in 1 oil just a coulp dorp.now it can be the rolls
Posted on Oct 15, 2010
Refrigerator is louder when it turns on maytag performa side by side model psd262lheb
sometimes, as the machine starts to get a little age on them, the Freon flowing through the unit will get a little loud during the first minute or so of cycling on and for about a minute after unit cycles off. could make banging sounds, popping sounds even might sounds like water running or rain. All those sounds are normal operational sounds. I would not worry about those sounds unless you start to notice a slow temp. increase in the next few months. If you start to notice cooling issues, then I would start to get concerned about a sealed system issue.
Feb 26, 2015 | Maytag Washing Machines
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
My dryer works right it's just when it's running
Usually lound screeching and squeaking noises are caused by dry drum rollers. You need to lube the rollers or replace them. When I say lube the roller I mean the shaft and bearing part of the roller.
Sep 24, 2009 | Hotpoint Dryers
Gradual squeaking increase
Check the drum's roller bearings - they sometimes look like large rollerblade wheels. The may need to be replaced. They are relatively inexpensive, and can usually be found at your local appliance parts store.
Too, check for a  felt "ring" around the front of drum (if applicable). Again, if too worn, replace it.
Jul 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Can not run spin cycle bang bang bang
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 04, 2009 | Washing Machines
Maytag Neptune model # mah6500aww: makes banging noise and causes machine to move
A loud banging sound in the pipes is usually caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The banging happens as the water hits the valve that prevents it from going any further. If the kinetic energy is great enough, it can actually cause a pipe to burst or explode at the end. If a valve is closed near the beginning or in the middle of a system, the water keeps flowing after that point, and it can actually create a vacuum. This vacuum can cause a pipe to implode if the stress is too great. Roaring type noises may be coming from a spin bearing. This bearing probably had the grease washed from it because of a tub seal leak.
Squeaking sounds in a new washer are usually caused by the new parts getting broken in, and will usually go away after several washes.
The sounds of water gurgling, slurping, or sloshing during a spin cycle are usually caused by the drain pump pushing the water out of the washer tub.
Too much water pressure can cause a whistling or squealing sound. Adjust the hot and cold intake water valves to relieve this sound.
Metallic clinking sounds during spin or agitation may be the result of drive train components meshing during speed changes or after a pause.
Swishing or swooshing type of sounds may be caused by water and suds trapped between the tub and basket during a spin cycle, and will usually clear up as the water is drained from the washer
Jul 29, 2008 | Maytag MAH6500 Neptune Front Loading...
Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
Dryers Logo
44 people viewed this question
Top Dryers Experts
