Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberlain chain gdo. goes all the way up until it hits gdo box and gets stuck. unstick it and it works for awhile then it happens again
    President:
  • 3,197 Answers
Unstick it and close the door. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Should be good to go.
Posted on Oct 15, 2010
Just moved into house with a chamberlain gdo and a liftmaster keypad. All was well until yesterday when I added the chamberlain car remotes and could only get them to work if I erased codes from gdo. Now...
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Nov 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
My 20 yr. old Craftsman 1/2HP chain drive GDO (139.18590) will click and hum for a second but the door doesn't move when I press a remote or wall console. The door moves freely manually and I checked the...
If your door is stuck in the open position the trolley is most likely jammed against the bolt just in front of the motor unit. You should be able to loosen the chain enough that it releases the pressure on the trolley and then close the door. While the door is closed, locate the 'up limit' control which is on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover and then tighten the chain.
Feb 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
My older Craftsman garage door opener comes down about 6" & then goes back up. I just replaced all the rollers o& the opener worked fine. Then I tightened the chain on the opener & it worked ok...
If the main light flashes 10 times when the door goes back up it is a door sensor problem. You chain should sag just a little. If you tighten it too much it will click as it goes over the sprocket. You can increase the down force which is an adjustment near where all those white wires go. A 1/4 turn should be enough. Release the door from the opener and operate it by hand. It should move freely and when you have the door approximately waist high it should stay put. Neither raising nor closing.
Jan 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have replaced drive gear on Craftsman GDO. Everthing engages and chain moves but door only opens 3 inches are so. Have ajusted opening cointrol on side to max and only 3 inches. When I unlatch GD from...
Loosen the chain enough that you can remove it from the pulley on top of the motor unit. Now with the door closed run the motor until the pulley turns in the clockwise direction and stops. Put the chain back on the pulley and tighten. You may have to tweak the up and down limits now.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2 HP Craftsman Garage Door Opener works but lights don't
I think you are saying that normal incandescent bulbs do not work. If that is correct you should unplug the unit and using a small screwdriver reach into the socket and pull out slightly on the center contact.
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster gdo won't operate with door or remote
Hi there, when the problem first started was the door being used frequently? If your GDO was used quite a few time's in a short period of time the "overload" may have triped. The makers of all GDO's now adays install an overload witch is an electrical safety device protecting the motor. This prevents over heating in turn burning up the motor. To rectify unplug for 15-20 mins. If you have Model number 1270 turn to pg. 7 in owners manuel. Insure all door locks are free. Insure power to electrical outlets by pluging desk lamp in same out as GDO. what model do you have?
Mar 17, 2009 | liftmaster Chamberlain Garage Door Opener...
Red light/stuck GDO Sears 139.53600
is it locked. does door lift manually. are springs/cables ok?
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
My GDO only goes down
sounds like down travel limit has to be backed off . if this always happened, chain may be out of sync.
Jan 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door Opener for 16 ft. door.
Sears sells RAIL EXTENDER KITS for most of thir GDO'S, mostly for residential applications. Go to www.SEARS.com, type GARAGE DOOR OPENERS in the SEARCH box. The first item that comes up is a 10 foot long GDO extension , item #00953727000, mfr model #53727.
Aug 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
80 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
