Question about Lexmark X4270 All-In-One InkJet Printer
Cant print or scan
My all in one keeps giving me error message alignment, I cleaned rollers,it tells me to load document then says document loaded then gives me another message to press the check button then tells me to load document . like it never reads the paper as being in the printer .
    Scholar:
  • 141 Answers
Hi carla;
that sounds pretty weird but you may want to try resetting it to default factory settings,just navigate through the menu if it still doesnt work, try re-installing the driver.
thanks
Posted on Jun 06, 2008
How do I fix a printing problem where the error message load tray 1 keeps appearing?
You Really need to have this Machine Cleaned. there is too Much Paper dust On the sensor
Jun 06, 2015 | Xerox 6505/dn Workcenter 6505dn Color...
Issue with scanning documents to PDF however no issues with printing documents
from the sounds of this you have dirt or something on the scanning lenses. you need to check where the document you are scanning is loading it is carried across a lens that creates the image, if this is dirty you will get your symptoms coming out. if you lift the cover where the document is feed in you can clean this lens with some glass cleaner and a soft cloth. if all is printing ok you will waste ink by carrying out cleaning and alignment programs so save your ink and check the lenses for scanned doc. Hope this helps.Andy
Mar 11, 2015 | Office Equipment & Supplies
D7160 error messages showing put the papers facing down , its correct selection from our side but keeps showing the messges
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
  • If the self-test report prints , try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.
  • If the self-test report prints, but the original document does not , continue to the next solution in this document.
  • If the self-test report does not print , try printing the report again. Listen for the rubber paper-pick rollers; you should be able to hear them rotating. Then, try slowly pushing the paper farther in until the roller engages to pick up the paper. Be careful not to push the paper in too far, which can cause paper jams.
    • If the self-test report does not print when slowly pushing the paper farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
    • If the self-test report prints when slowly pushing the paper farther in , try printing the original document again. The paper might not have been loaded far enough into the product. If the issue is resolved, there is no need to continue troubleshooting.
    • If the paper only feeds through the product when you slowly push it farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
Nov 18, 2010 | HP Photosmart D7160 InkJet Printer
Ever time I try to print anything, I get a message saying the printer is out of paper. But it's not out of paper! There is plenty of paper in the tray, which I keep reloading, only to get the same...
Cause
Any of the following issues can cause this issue:
The paper trays are empty or overloaded.
The paper is curled.
The print side, or shiny side, of the paper is not loaded in the tray face down. For photo paper, always load the rougher side of the paper facing up.
The paper is too slick for the product.
The paper might not be engaged with the feed rollers.
The paper-width guide is pressed against the paper stack too tightly.
The paper tray is not completely inserted into the product.
The paper settings in the print driver do not match the paper loaded in the paper tray.
The rubber paper-feed rollers are dusty.
Check the media and print settings
a)While the printer is on, remove the power cord from the back of the printer, wait 30 seconds, and then plug the power cord into the back of the printer.
b)If the printer is not already on, turn it on by pushing the power button.Replace any paper that is ripped, dusty, wrinkled, or bent. If the paper is curled, uncurl the paper by gently bending it in the opposite direction of the curl or replace the paper.
c)Verify that all the paper is the same size and type.
d)Tap the stack of paper on a flat surface to align the edges
e)Verify that the stack of paper to be loaded in the unit contains between 10 and 25 sheets of paper.
f)Insert the stack of paper into the printer and then gently push the paper guides snugly against the paper.
g)Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
1.Open a document in the application in which it was created.
2.Click File
3.Click Print
4.Click Properties . The Printer Properties dialog box displays.
5.Click the Paper/Quality tab.
6.In the Size is drop-down menu, select the size of the paper loaded in the unit.
7.In the Type is drop-down menu, select the type of paper loaded in the unit.
8.click ok.
9.On the Print dialog box, click OK to print the document.
10.Try printing again.
If the issue is not solved, try next steps
1.Turn off the product and unplug the power cord.
2.Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door.
3.Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
4.Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
5.Close the access door and plug in the power cord.
6.Try printing again.
Sep 16, 2010 | HP Officejet 6000 All-In-One InkJet...
HP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Oct 03, 2009 | HP Officejet 6500 Wireless All-in-One...
Have installed new printer a message pops up saying the printer is out of paper even though there is plenty of paper in tray.
Hey buddy,
Follow the below steps:
Step one:
NOTE: Use plain paper in the unit until the issue is resolved.
NOTE: Do not load too much paper in the printer.
Click File .
Click Print .
Click OK .
NOTE: These changes do not change the default print settings. The print settings will revert to the default print settings the next time the application is opened.
Try printing again. If the issue is not solved, continue on to the next section.
NOTE: If the issue is resolved and you want to print on another type of media, change the paper in the unit and then repeat steps 2 through 7 for the new media.
Step two: Clean the rollers
NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
Step three: Service the product
If you have completed all the steps and are still experiencing a problem, service your product.
Cause of this problem:
Sep 22, 2008 | HP Computers & Internet
Paper size problem
clean the roller with a cloth using isopropyl liquid and if there's any paper stuck
Jul 23, 2008 | HP PSC 1510 All-In-One InkJet Printer
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
Alighning test
Problem The following error message appears on the LCD panel on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected. Step 1 - Check the paper Make sure the printer is loaded with clean, unused, white paper. If the paper is not feeding properly, check the paper path. For information about how to do that, see the instructions under "If the paper does not feed correctly" at the end of this document. Step 2 - Remove and inspect the cartridges
NOTE: The "problem" cartridge is the cartridge indicated by the error message.
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge. Figure 1: Removing the cartridge c00143341.gif
Mar 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
