Question about Panasonic Cell Phones
I'm installing a Panasonic 616 EASA Key system and I'm attempting to program it. I've gotten the manual for it. Some of the Program Codes in the manual either don't work or give me a different LCD read-out. I am using a KX-T7030 station phone for the programming. I know that the system needs to be switch to "Program". The book says to switch the KX-T7030 Memory to Program as well, but it does not seem make a difference once the system is switch to Program. The 2 main codes that are not functioning according to the manual are "99" for System Clear or defaulting the system to manufacture's setting. I get the Error beeping sound when entering the 99 code and nothing happens. The other code is "03" for CO Connection Assignments in order to narrow the CO's actually active on the system. The book says "CO CONNECTION" will appear after entering code 03, it does not. I get the following read-out on the LCD: "C..-T.., C..-T..". I have figured out that the -T.. is for the Ex 11-26. Logically the C.. is for the CO lines 1-6, but I don't know what code format is correct for the CO lines. I suspect the system has had it's firmware upgraded and/or programming with the KX-T7030 is the issue. Any help is greatfully appreciated.
  • 6 more comments
  • Dean Akin Oct 16, 2010
    I downloaded a scaned copy of the manufacture's install manual. I also have the Install
    I have downloaded a scaned copy of the original manufacture's manual. I also have a copy of the Install & Operation Manual for Added and Changed Features for the "Mark 3" system update. The update stated the codes "99" and "03" have been deleted. My question now is: What code replaced the code 03?
    OK, but I don't have the paid version at this time. I need advise on how to work with what I have.
    Since I need to work with what I have, can you provide anymore assistance or direction regarding the programming codes?
    I believe that that the system I'm working on has the "Mark 3" system update. Program Code "03" has been deleted, what code replaced it. Assuming the system is updated, it could be code "15" for Preferred CO Line Assignment, but I'm not sure.
    This is what I figured and I feel positive that this will be the fix. I will give the programing a try this Monday and let you know how it goes.
  • Dean Akin Oct 17, 2010
    I did miss that part and understand now. Thanks, I'll let you know how it goes tomorrow.
  • Dean Akin Oct 20, 2010
    Hey Carl, this was exactly the fix, but I don't have the option to "accept this solution", What's up with that?
    Anyway, I got the system programmed today, thanks.
  • Panasonic Master
  • 2,460 Answers
There are 3 versions of the software for the KX-T61610 system, and also a KXT-616D box. The nameplate of the 10 has a revision number in a circle, or not, which would be either circle 2 or circle 3. Since program 03 was deleted (Connect/No Connect) in 3, I'm guessing that's what you have.
Unfortunately, they issued a basic manual and addendums and you have to know which one you have in order to program the box. Your PROGRAM button on the back of a phone doesn't do anything in this case, just the SET/PROGRAM switch on the cabinet. When you set it to PROG, the phone will say Sys Prog ? or something similar. Here's a link to circle 3 software. You'll know even if the plate doesn't have circle 3 because it has a program 44. Also, your 03 program is Console/Telephone for pairing a DSS console to an extension....really useful if you have a 7040 unit :-) http://www.public.carl.airpost.net/Pana/KXT-Analog/t61610B_inst.pdf
Please note that there's a FOURTH programming guide, and this is it. The codes and description should be similar, but this is for a European system and there was no doorphone control and they had internal music. The companion R3 codes are found here http://public.carl.airpost.net/Pana/KXT-Analog/R3_program_codes.pdf
Anyway, to ease your Connect/No Connect issue, you program out the vacant lines in 07 and 08.
Hey, I told you it wasn't going to be easy :-)
Carl
Posted on Oct 16, 2010
  • Carl Navarro
    Carl Navarro Oct 17, 2010
    What was the last line of my post, or didn't you read it through? PROGRAM 07 and 08. You have to deny outgoing access day and night to the missing lines. You could also erase CO x-6 on the phone and it blocks out access because the line has to appear on the phone to use it, but 07/08 is better.
    PLA just gives you the ability to select a different line to make outbound calls. IIRC if you pick, say line 3, and it's busy, you still have to select a line to make a call.
  • Carl Navarro
    Somehow, the follow-up response got lost in the shuffle. The last lines of the post gave you instructions...program 07 and 08 need to be changed to delete access to the vacant CO lines or, you could program out the CO buttons on every phone since a phone has to have the line appearing on it to get access. I'd pick the first idea.
    Program 15, PLA, only gives you access to a specific line (like making calls on line 3 first), but IIRC if that line is busy, you still have to select a line to make a call.
  • 712 Answers
Have you bought the original manual? From where have you arranged the manual?
  • Sebin Punnacheril
    Sebin Punnacheril Oct 16, 2010
    A paid version of manual would have been more helpful in such situations.
I have a Panasonic Easa-phone Model KX T-3135. I need information on how to program the memory to use the automatic dialer keys.
Panasonic ESA-PHONE - KX-T3135
Program instructions for the "Automatic Dialer"
On the right side of phone set the 'Memory' switch from 'Set' to 'Program'
If programing the upper entry of a 'Automatic Dialer' buttons:
Press the button - enter the phone number as it needs to be dialed - press the 'Memory' key on the left side of the phone's face.
If programing the lower entry of a speed dial buttons:
Press the 'lower' button on the left side at the bottom of the 'Automatic Dialer' pad;
When all entries are complete, on the right side of phone slide the 'Memory' switch from 'Program' to 'Set'.
May 03, 2011 | Cell Phones
Unable to dial 1800xxx or any other 1xxxx numbers
The things that control restriction (TRS) is class of service and Allow/Deny codes, or it may be in the dialing restrictions of the station.
Your system administrator or manual will have specific instructions on how to program the system as it's beyond the scope of a free and public forum to tell you how it's done. Once you understand it, it's a pretty simple program. In the U.S., we actually screen up to 10 digits, allowing 1800,1888,1877 etc. and denying everything else. We don't have the TA-616, but we do have the TA-624/824. Programming gives you about 20-25 allow and deny tables. If you do score a manual, check out TRS.
Carl
Jul 05, 2010 | Panasonic KX-TA308 Phone
Kx 616 easa phone problem
Unfortunately, The KX-T 61610 system was made before featured cordless handsets were available, but any cordless (or any SLT for that matter) should be able to access any feature in the system providing it uses the SLT feature codes. I've added a Panasonic SLT users guide link for reference.
http://www.wedophones.com/Manuals/Panasonic/KX-T%20616/KX-T616%20Station%20User%20Guide.pdf
Jun 04, 2010 | Lands Phones
I need programing instructions for a Panasonic Easa-Phone model KX-T3170
For the onetouch buttons 1)push program untill memory light is on. 2) push desired onetouch button,
dial the phone number. 3) push auto button 4) when done press program button.
Feb 28, 2008 | Panasonic Lands Phones
Panasonic kxt7730
Here is a link for the 7730 manual.
http://www.walterbridge.com/manuales/KXT7720-User-Guide.pdf
Aug 30, 2007 | Panasonic KX-T7730 Corded Phone
Cell Phones Logo
458 people viewed this question
Top Panasonic Cell Phones Experts
Rommel Balcita
ray gallant
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
