Question about Canon PowerShot A630 Digital Camera
Hello, the flash don't work with the shutter in all mode P A ... and the image are under exposed : there is no flash light on the photo. Thanks for your help, José , in FRANCE
  • Canon Master
  • 3,866 Answers
My experience with these power shots is the flash capacitor unit witch draws current from the battery, Fills up then activates the flash is what your primary issue is.
hello, the flash don't work - 654137e.jpg its ether that or the flash bulb itself without further look I would not be able to pinpoint it. If you value this camera you might want to take it to a camera shop.
please do be considerate and leave ratings or feedback before you leave, Thanks
Posted on Oct 15, 2010
Testimonial: "merci, thanks for this faster answer, but the flash appear to me have a normal function because in manuel mode the exposure is correct.Synchro?"
  • 3 more comments
  • Grand Canyon Tech
    Grand Canyon Tech Oct 19, 2010
    Ether the flash is working or not?
    is this flash bulb working in normal mode?
    if not answer still stands Bulb or Cap
    if it is workign in normal mode then we need to work deeper in the issue.
  • jose_falchi Oct 19, 2010
    I'am not a very good english, but I try to explain you the problem.
    flash bulb is always with light but there is no exposure with this light ... only the Tv, Av and M mode have flash light visible on the photo! For Tv and Av mode only if "ajustement flash" is en "manual". Other photo are with a strong under exposition : out of couplage?
    J have an Open office file with all these fact.
    The camera is with good fonction without flash (sunshine)
    thanks.
  • Grand Canyon Tech
    So if flash is working, then we are talking a ADF sensor in the camera this is called the autofocus sensor witch will need a camera shop likewise of the issue.
    Let me know ether way I still trying to help.
  • Shahid Electronics
    Shahid Electronics Oct 27, 2010
  • dr_q Aug 20, 2011
    I had the same problem on my A630. Since I did not use the camera in over a year because of the flash issue I took it apart to see if I could fix it. The flash module(PCB for the flash) in the camera has a little white control connector on the side of the PCB toward the center. There is a white ribbon cable with a green tab on the end connecting to it. After probing around around selectively on the flash board until I got the flash to trigger lead me to this connector. I used a pair on my electrical needle nose pliers to re-seat this and my flash now works again. It looks like this connecter end up loose or gets corrosion on it. This is most like why tapping the camera / the flash cap shakes this board and helps (temporary) seat this. You have to take the top and back off the camera to get to this connector. It is fairly easy with a small phillips head screw driver. Be careful on the top plate as there is a delicate ribbon cable attaching the top electronics to the camera base and make sure to track where each screw comes out as they are all different sizes. There is a tab on the left side of the view finder hold the top to the back panel. This was the most tricky to locate why the top would not just pop off. All screws are visible and there are three in the battery compartment. Hope this helps people fix the flash issue. I love the camera put had to stop using it because of this. Yeah I got my point and shoot back.
PICTURES ARE BLACK
6 Ways To Fix Too Bright and Too Dark Photos
Recompose The Photo This is probably the simplest solution. When taking a photo of a scene with very bright and very dark parts, move your camera to eliminate one of the extremes. In the case of the band, I would have either closed the curtains for the shot, or recomposed completely and photographed from the window looking at the band, and the crowd behind.
Use Exposure Lock If you can't recompose the photograph, instead tell the camera what part of the image you would like to see. The rest of the photo will be either over or under exposed (too bright or too dark) but at least you will see your subject. You can dothis by placing the center of the image at your subject; half depressing the shutter to lock the focus and exposure; move the camera to re-compose the image; and fully depressing the shutter.
In the band image, the camera chose to correctly expose the scene outside, but even if the band member had been correctly exposed, the window would have ended up being over exposed and you would just have seen white.
Some cameras have an option called 'spot metering' to set the part of the image you'd like to be correctly exposed. If your camera has this setting, enable it before using the technique above.
Use Fill In Flash If your scene has a sunny background, but your subject is in the shade (or has a hat on), turn on the flash (as I explained way back in tip number 9 - Using Flash During The Day). I know it seems wrong but it really does work! By using the flash, your subject will look as bright as the background. This would have worked well for the child shot above.
High Dynamic Range Imaging This technique is not for the faintof hearted. It requires a subject that does not move; a good camera with the capability to set the exposure and output RAW images. A tripod and image editing software like Photoshop CS3 are also needed.
High Dynamic Range Imaging (or HDR for short) is a technique for placing both very dark and very light areas in the same photo. It requires you to take a number of photographs of thesame scene - each with a different exposure. First take the shot using the camera's recommended settings. Then, in manual mode and keeping the aperture at the same value as the first shot, take a sequence of shots - each shot having a different shutter speed (above and below the original). You'll have 5-9 shots of the same scene all in different exposures.
Merging the three images to the left creates the HDR image below. Thanks to Photomatix for the images.
hdrmerged.jpgNow import these into your favorite paint program. I use Photoshop, but you can as easily use a cheaper program designed specifically for HDR photos like Photomatix. Follow the HDR directions and the paint program will merge these images into one great looking shot!
Use a Filter If your scene is of a brightsky and a dark ground (for instance at sunset, or on a cloudy day), you can use a graduated neutral density filter. This filter cuts out someof the light from one part of the photo (the sky). This will correctly expose the ground and the sky without needing to use HDR. These filterscan be complex to setup, so I don't usually recommend them for beginners.
Fix The Original Photo in an Image Editing Program twobright2.jpgFinally, if you can't take another shot at the same location, you can fix the original image by changing the levels using a paint program. This works best when your subject is darker than the rest of the photo (because cameras lose detail in over-bright areas). I've brightened the band member in the top image using this technique and while it looks okay in thissmall shot, this technique can tend to amplify any noise in the image. The darker the subject, the harder time you will have fixing the image.
I discuss exactly how to use this technique in lesson 2 of my free Image Editing Secrets course. I have a tutorial for Photoshop, Photoshop Elements, Paint Shop Pro and the free Google Picassa.
- See more at: http://www.digital-photo-secrets.com/tip/140/6-ways-to-fix-too-bright-and-too-dark-photos/#sthash.58eENOTt.dpuf
Jul 09, 2014 | Nikon D3000 Digital Camera
Hi, the photos i take are getting blurred and the image is not at all clear no matter how shot the distance may be i click the image.the only new icon i see on the screen is vibration warning symbol along...
If you are shooting in Auto mode with flash, this should solve your problem. Make sure you are not dictating any of the settings, i.e. choosing a longer shutter speed, a very small aperture setting, or a very low ISO (sensitivity) setting.
Typically the vibration warning icon will appear when the camera is trying to use a long shutter speed without flash in order to get the right exposure for a darker scene. Your outdoor (bright light) photos are probably OK.
In dim light with a point and shoot camera, you can have your choice between 1. blurry (using a relatively slow shutter speed), 2. dark (using a shorter shutter speed but no flash), or 3. a good photo with flash (which uses a medium shutter speed and added light from the flash)
Mar 12, 2011 | Cameras
Grainy photos. Blur in low light. I have tried all the settings and nothing is helping.
Grainy photos is due to high ISO that is needed to capture photos in low light. The solution to that problem is to use flash.
Blur in low light would be due to a long shutter speed in an attempt to capture enough light to get a properly exposed photo. Again, the solution here is to use flash.
Auto mode with flash on is just fine in this situation-- you could also try night mode if you wish.
Mar 11, 2011 | Nikon COOLPIX S230 Digital Camera
At the time of photo taken in zoom please instruct me actual shutter speed & exposer in which better photo is taken pranab
Pranab, When using a zoom or telephoto lens, it's just like using a telescope - a little bit of movement in your hand makes the image jump around a lot. If you take a picture under these conditions it is often blurry. There are 5 things to improve the image quality: 1. Use the fastest shutter speed possible. 2. Since a fast shutter speed captures less light, you also need a wider aperture (that's the size of adjustable curtain in the lens known as the f-stop, a smaller f-stop number indicates a wider aperture). The wider aperture allows more light in. 3. Use a tripod. This works for telescopes and cameras. 4. Bright available light. On a sunny day, there is lots of light available, so you can use a fast shutter speed and still get enough light. 5a. On film cameras use "fast film". This film is more sensitive, meaning it requires less light so you can use a faster shutter speed. 5b. On some digital cameras there is Image Stabilization. The image is electronically stabilized - this is like using a tripod to hold the image still, while allowing the camera to move around a little bit. I hope you found this helpful good luck Al K
Jan 12, 2011 | Garden
I have a Kodak Easyshare model dx5430 digital camera (5mp). It has worked like a champ for years. Last night I was at an event when the image display went dark at picture 31. All preceding photos were able...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 01, 2010 | Canon PowerShot A75 Digital Camera
I have a NIKON D40 and want to shoot on MANUAL MODE and taking pics of my son's basketball game and NOT getting clear pictures, what settings do I use for that?
Based on the following descriptions: http://www.imaging-resource.com/PRODS/ND40/ND40MENUS.HTM
I'd say use the little person running, or 'Sports' mode. This basically chooses a high (fast) ISO and fast shutter speed, in attempt to let the most light in and reduce the exposure length to reduce blur.
Hope this helps.
Oh, FYI, manual mode is very useful...if you find a shutter speed and f-stop (aperture) that works for your setting -- which can be seen in the viewfinder or on the status LED on the top of the camera -- you can set the camera to those settings and know that the shots should turn out well, where any 'automatic' type setting is very convenient, it has the potential of adjusting the lighting based on the wrong 'subject' of the photo and leaving you with a under or over-exposed photo. Best of luck!
Jan 04, 2010 | Nikon D40x Digital Camera
FinePix F470 Lines on images and faded colors on photo mode.
You have over exposed pictures due to the shutter sticking.
The video is the clue to the problem. It doesn't use the shutter.
Shutter needs to be cleaned. This is no easy task im afraid
Sep 11, 2009 | Fuji FinePix F470 Digital Camera
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Having problems with the flash\ blurred and grainy images
You should not use the flash for these shots (unless you connect a powerful external flash), it won't help you at this distance. You should use the shutter priority mode and experiment with shutter speed (no flash) to get the best result - for sports action it should probably be faster than 1/100 sec. If the light is too low you may use higher ISO setting - 200 or 400 (though higher ISO will result in grainier images, it may be your only option for blur-free photos).
Sep 07, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
Canon PowerShot A630 Digital Camera Logo
970 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
