Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
My pool heater turns on, runs a few minutes, the igniter lights and the heater heats for about 3 minutes, then turns off. I see a SERVICE comment blinking and SW2 is also blinking.
Im not sure what filter you have on there but do a good cleaning if its D.E acid wash it if sand clean the sand. your not keeping enuff pressure to keep it lite. take it slo
Posted on Nov 24, 2010
Pilot stays lite but burner won't ignite
you have either an open safety, poor wiring connection, or problem with tstat controls
Apr 15, 2014 | Zodiac Jandy Legacy LRZ 175K Commercial...
My Teledyne Laars LLD spa heaters starts and heats for a couple of minutes thins shuts down. I have tried this several times with the same results. I hear the switch click and then the heater ignites and...
Since the heater fires it sounds like it could be the bypass valve stuck open. The bypass valve allows some of the water to enter the heater, while the rest bypasses the heater and returns to the pool.
If the bypass is stuck open, or broken, it allows the vast majority of the water to bypass the heater and continue to the pool. The water that is in the heat exchanger will become too hot due to slow flow and activate the high limit switch, turning the heater off.
The bypass is located where the pipes attach to the heater and can be checked or replaced if needed fairly easily.
Apr 16, 2013 | Pool & Spa
R=8 128 Code on Pentair Mastertemp Heater what does it mean?
check manual bypass possible overheating or running out of gas
Apr 10, 2012 | Pentair Mastertemp Heater
My wife said the pump timed off and the heater was heating. She shut the heater off and restarted the pump and now the heater won't ignite. The red light blinks three times and I am not sure how to get it...
The fan will continue to run for a few minutes after the pump turns off to purge exhaust gasses.If it was still heating you have a problem. To reset the heater,turn off the pump breaker for 30 seconds. After that you need a repairman.
Sep 27, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Hayward Heater Problem ''AO'' error. H400IDH
Thank you for posting your question here on Fixya.com.
It sounds as if the air activated switch the tube you mention attaches to is not working. Pull the two wires from it and connect them to simulate the switch closing. Start up the heater to see if you get ignition. If so, replace the switch.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 14, 2010 | Hayward H Series Pool & Spa Heater 400k...
Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Jan 09, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Service light on
I just had the same problem resolved, my mastertemp 400 would run up the temp to 82F and then cutoff, the service light flashes and then 50 seconds later the heater would restart and run for 2 minnutesbefore shutting down again and relighting in 50 seconds. Repeating until the temp setting is reached.
I had the pool guy out 3 times until he found a bad thermal regulator valve (kit #77707-0010). Once replaced the heater runs great.
He told me that it's my pool chemestry that is to blame, I had it checked (like I do weekely by me and monthly by the pool supply store) and it perfect??? I'm now questioning what caused the corroson and stop it from coming back?
I hope tis helps.
Jan 17, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Heating & Cooling Logo
93 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
