Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Water will not shut off. Floods floor - GE Spacemaker Washer and Dryer Electric Laundry Center
    Sergeant:
    Champion:
  • 226 Answers
Water over flow it hanging
Posted on Oct 15, 2010
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Dec 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
Hi, What controls the water level and turns off the cold water shut-off solenoid on an Admiral washer? It sometimes sticks and floods the floor. Thanks
the water level switch (the knob that say low med. extra lg. ect) controls the water level, it probably isnt the trouble, but i suspect that the water valve (where the hoses attach)is sticking open to determine this,when it does flood unplug the machine if it continues to fill while unplugged the valve indeed is sticking
Jul 20, 2011 | Admiral Washing Machines
Tub fills with water and won't shut off, then floods on the floor
Your water level switch has a small hose going to it. The hose may be pinced ,have a hole in it, or simply vibrated off the water level control.
This link has 4 videos which include how to access the controls and more:
How it works: Direct drive washer
This link has lots of other good stuff:
Manuals and more photos HERE
Oct 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Floods floor on startup. Pump not leaking. What
The tub was off center and the fill water was splashing over the rim. This happened because I had removed the pump to oil the seal. The washer sets all summer in 110 degree weather and very callcifeid water. Last fall on start up the seal was siezed to the shaft because of calcium build up. I was able to recenter the tub by pulling it the opposite way. Hopes this helps someone along the way.
Sep 20, 2009 | Roper RTW4300SQ Top Load Washer
Water level will not stop and floods floor
check the level switch by blowing on it if clicks is good if not replace the switch , make sure that the hose that connects to the switch is free of debri
Jun 18, 2009 | Kenmore 22422 Top Load Washer
Overflow
Check water valve may not be shutting off .
Check water level switch , or hose going to it from tub must be air tight may have pin hole in it.
Water level switch is the one that says small , medium or large on some washers.
Jun 10, 2009 | GE WBSE2090A Top Load Washer
If I do a small load after a large load, on the rinse cycle teh water gushed up through the drain in the floor and floods the floor. The plumber snaked 50 feet twice and poured down acid and it still
Since the plumber snaked 50 feet, one must conclude that the blockage is beyond the 50 foot mark.
Shame on the plumber who stopped at 50 feet. he should have snaked all the way to the street system if you live in a city or to the septic tank if you live in the country.
I would call him back and tell him that he needs to finish the job.
May 21, 2009 | GE WWSE5200B Top Load Washer
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My maytag neptune sometimes fills with water and floods my floor
sjhtlh
It sounds like the water valve is starting to go. i would get a tech out just to make sure.
brent
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
27 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
