Question about Refrigerators
Water is leeking out bottom of freezer - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
Freezer defrost working but leeks
Hey friend, I appreciate the post!
I understand that your refrigerator is defrosting but you are getting a patch of ice to form due to water leaking inside the freezer. It may be a moisture build up in your freezer. Which may be caused by the door being slightly opened, when that happens warm air can enter the refrigerator and cause a moisture build up. You could also check to see if your door seal is bad, the way to test that is to place a dollar bill between the body of the refrigerator and close to the door. Pull the dollar bill out, if it sticks it is good, but if bill comes out easily the gasket need to be checked. Hope this is helpful- Matt
Jul 19, 2014 | Frigidaire Refrigerators
MAYTAG REFRIGERATOR LEEKING WATER
Have you checked and cleared the drain in the bottom at the back?
Mar 26, 2012 | Maytag Refrigerators
Leeking water inside fridge from top
Defrost drain is clogged. This accessable thru the back wall of the freezer. Also depending on your model some also have removable Bottom floors of freezer that also get ice accumulation. When the defrost drain gets clogged water from the defrost cycle has no where to go so it stays and accumulates ice till eventually it leaks into the fresh food section. Clear the drain completly and you will have no more problems.
Feb 02, 2010 | Freezers
Freezer is leeking water into the bottom of it ,
I had the same problem.
This is how I solved it.
Remove the bottom drawer of the freezer. There was a lot of ice built up.
I chiseled it out, and then looked in the back.
There is a drain hole that was blocked by a fallen popsicle that melted, and then the plastic wrapper plugged the hole.
Check that the hole is not blocked.
Also, it is always a good idea to remove the bottom black vent cover under the fridge and clean out any dust build up with a vacuum.
Good luck.
Oct 24, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leeks from the bottom of daewoo FRSU20FAI freezer door when dispensing water
There is a joint at the bottom of the door which can be loose and leaking. If it's not leaking there it would be hard to replace the water line in the door.
Sep 21, 2009 | Refrigerators
I keep finding water at the bottom under the drawers
in the compressor compartment theres a tube white its blocked jus clean or blow on it
Jun 18, 2009 | Frigidaire FRT21P5A Top Freezer...
My side by side refrigerator leeks water from somewhere in the freezer and freezes at the inside bottom of freezer i have to hit it with a hard abject to break ice and remove at least onece a week
there is a defrost drain just below the coils in the back of freezer. check for blockage or may be frozen inside hole. hairdryer will do the trick but be careful..will melt the plastic if not careful.
Jun 11, 2009 | Freezers
Water leaking at bottom of freezer door where water line goes into door
DRAIN IS STOPPED UP! IS THIS A TOP AND BOTTOM OR A SIDE X SIDE?
Apr 27, 2009 | Freezers
Water leeking on floor
most fridges and freezers have a small outlet hole at the very back of the inside make sure this is clear should have a small tub at the back of your appliance on the outside try this
Aug 15, 2007 | Kenmore 62232 / 62234 / 62239 Bottom...
ET1CHMXKQ02 TOP FREEZER REF.
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Mar 17, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
