Question about Bugaboo Cameleon Jogger
Is there a store or person who can repair a Bugaboo Cameleon chassis in the Boston, MA area? I'm having trouble with the handle bar. The small white tab on the right side is stuck and so the handle bar won't lock into position; it just falls to the ground.
    Guru:
  • 541 Answers
How to fix a Bugaboo Handle
If you are not a handyperson type, take these instructions to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused by two small plastic pins shearing of a plastic disk that actuates two metal locking rods. Why bugaboo uses a plastic disk for this critical component is beyond me!
1/. Remove the domed star lock washer. This is the hardest part of the job. Most people try to leaver this off in the hope of re using. First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement. A hardware store should be able to source some for you. Quickest way to remove a dome washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to carefully prize one side up so you can fit a screwdriver. Note the walls of the aluminum hub axel are thin and easily distorted, make sure you only lever the Domed Star Lock and not hub axel. Use one screwdriver as a support and another to lift off the Domed Star lock.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side. The hub and disks are mirrors of each other and not interchangeable. The side with the brake lever is left The Bugaboo parts will have an "L" after their serial numbers.
2/. The lock mechanism is very simple; a wire rod rotates a plastic disk. Check the hubs for ware. If too badly worn or damaged you will have too much movement in the locked position. The Frog and Chameleon use the same plastic hub find another frame to salvage hubs from. They are held in by a single aluminum rivet.
The disk has two plastic pins that move the locking rods in and out of the inner hub into and out of the outer hub. You need to either repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in. Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.
3/. Reassemble handle locking hub and check operation. If wire rods seem to be in the incorrect position, loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws and wiggle things into alignment. (I use a small amount of the grease used for taps to give a smooth action) If all is working well fit the new star dome on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern. Repeat operation on the other side
I have available kits with two (left & right) laser cut metal disks with stainless steel pins fitted and two new star dome washers. Cost is $150 New Zealand plus shipping. If you like a set, you can contact me macnutz@xnet.cIs there a store or person who can repair a - macnutz_2.jpg>
Regards
Posted on Nov 02, 2010
Can I modify the handle bars on a Frog? I need to lower them for Mum under 5ft tall? Take then off and replace with adjustable handlebar? Which part would I need to purchase? Is it in stock? price?
The Cameleon has the adjustable handle it is not available as a part only as a complete chassis for around $400 www.babycare.nl/bugaboo-cameleon-chassis-p-2466.html. Your Frog wheels, seat etc would fit. If you found a broken Cam frame on eBay you could swap the handles. Your Frog would have the parts required to fix the Cam. Click on this link to my tips section www.fixya.com/support/r7805199-fix_bugaboo_handle_lock. Note as you don't need the old Frog handle you could try prizing off and reusing the domes but I don't recommend that. Brake cable is compatible.
Aug 05, 2011 | Bugaboo Frog - Black Stroller
I have a bugaboo cameleon 1st generation that has a fault. If i was to buy a new 2nd edition chassis would my carrycot still fix on to this chassis.
I have a second hand chameleon and it feels like the frame is a little loose. Is there any way that you could tighten the frame up?
May 10, 2011 | Bugaboo 'Cameleon' Stroller
My bugaboo cameleon chassis 2007 model won't open,
Go to www.buggypitstop.co.uk they are the only company that repairs bugaboo chassis
May 19, 2010 | Bugaboo Cameleon Jogger
Cameleon 2006 known fault with Bugaboo
Your problem will be solved at www.buggypitstop.co.uk they will be able to repair your handle at faction of the price of a new one. They are Great.... oh ps speak to Fred good luck
Oct 08, 2009 | Bugaboo Cameleon Jogger
Bugaboo Cameleon
There a company based in London www.buggypitstop.co.uk and they do repairs to bugaboo's
Oct 03, 2009 | Bugaboo Cameleon Stroller
Bugaboo cameleon
Based on what you have described, it sounds like the silver domed cover (where the handle meets the bottom of the chassis) may be damaged, this may mean a new chassis is required.
I would suggest that you contact your retailer for repair advice (if this is still within the warranty period) or contact Bugaboo directly on the website link below:
www.bugaboo.com
Please note that you will need to have your chassis serial number to hand.
I hope this helps.
Jul 02, 2009 | Bugaboo Cameleon Jogger
Bugaboo cameleon handle bar
HIYA.... YOUR BEST BET IS... TAKE THE HANDLE BAR BACK OFF AGAIN. TAKE THE SPRING OUT OF THE SIDE THAT WORKS FINE AND TAKE IT TO YOUR LOCAL DIY STORE AND GET A REPLACEMENT, IF YOU CANT FIND IT ASK SOMEONE IM SURE SOMEONE WILL BE ABLE TO SEND YOU IN THE RIGHT DIRECTION... PROVIDING ITS JUST THE SPRING, IF YOU BUY ANOTHER TO REPLACE THE BROKEN/LOST 1
THIS SHOULD SOLVE THE PROBLEM :)
Dec 08, 2008 | Bugaboo Frog Stroller
Bugaboo cameleon problem
call bugaboo depends what it is sometimes it can be fixed
Tel # 1-800-460-2922
Sep 12, 2008 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Jogger Logo
475 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
