Question about Estate TAWX700JQ Top Load Washer
Oil under the washing machine - Estate TAWX700JQ Top Load Washer
    Sergeant:
    Champion:
  • 226 Answers
Transnission bad
Posted on Oct 15, 2010
Why am I seeing clear oil under my washing machine?
Your vent hole on your gear casing is clogged so the oil leaks out
Apr 16, 2015 | Washing Machines
Maytag PAV2300AWW has oil in dust cap.
There is alot of oil in a transmission it could last another 4 or 5 years. the only problem is the oil eats the belts up.
Feb 14, 2013 | Maytag PAV2300 Top Load Washer
Oil is leaking from under washing machine. Looks like motor oil but has no odor. Is this fixable and if so, approx. how much would it cost ?
The only device holding oil under your washer is the transmission. If your washer still has agitate and spin cycles the transmission has not failed but being that there is a leak it will fail soon. Depending on the washer a transmission can be from about 180.00 to 230.00 if you buy the part yourself and do your own labor. If you feel like wrestling with it the front cabinet is held on with two clips under the control panel.
Jul 18, 2011 | Maytag Washing Machines
I am finding oil under my washer.
your transmissions lower oil seal is leaking and needs to be replaced,if the top seal goes,you will start to see oil droplets on your clothes when washed and this is called "wash-back"
Jan 01, 2011 | GE WBSR3140DW Top Load Washer
Oil on the floor under the washer
The gear case you are referring to is actually the transmission, and yes this is not a good sign. The seal has gone out. its usually cheaper to get another washer than repairing the old one. However if you would rather repair this one then i would try to shop around and find the best bargain.
Jun 14, 2009 | Kenmore 22622 Top Load Washer
Found oil and grease under washing machine. Makes loud noise when on spin cycle.
The oil and grease is probably from the transmission and yes you might be able to replace it. Get your make andmodel number and go to www.repairclinic.com. It is a very good site for finding pictures and parts of appliances. The parts are as cheap as you will find them. If the oil/grease is from the transmission, it will eventually fail. Fix it now or fix it later. Your choice.
May 30, 2009 | Whirlpool Washing Machines
Oil spill under washing machine
Sorry, this could be bad. The transmission might have blown a seal. It's a big job to fix, if this is the problem. It might be time to consider replacing the machine.
Premmy
Oct 21, 2008 | Washing Machines
Washing machine will not spin during spin cycle (it will if you give the drum a turn by hand)
Tilt the machine back enough to inspect the under side. Inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin. The gearcase and clutch will have to be replaced.
Jun 29, 2008 | Whirlpool Washing Machines
Oil/Grease under washer machine
Nash, your unit appears to be made by Whirlpool. (Kenmore doesn't manufacture anything, they purchase from major manufacturers and put the "kenmore" name on them) If, as I suspect, it is made by Whirlpool... the top transmission seal is failed allowing small amounts of water to enter the tranny. The water, being heavier than oil, will displace the oil through the top of the tranny... out through a "weep" hole. The weep hole is not designed to allow fluid to escape, it's designed to allow air to enter and exit the transmission housing, compensating for the heat expansion and contraction of the lubricant that should be contained within. Regardless of the manufacturer, you have a main drive system failure on your hands. It'll only get worse from here. Most manufacturers put a 5 year warranty on their drive-trains, you should call them immediately. If it's over 5 years old, it's a very expensive repair.
Aug 30, 2007 | Kenmore 22642 Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
27 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
