How do they come apart so i can fix the wiring?
  • 32 Answers
LOL WOW ! the motherboard doesn't itself come apart. you can open the case and remove the processor, ram, any cards and the cables along with any other hardware, but to even try to solder the board which is layers of circuits printed sandwiched with layers of nonconductive with heatsinks is nigh on impossible. you can try to troubleshoot by component with an o scope and a sig gen but you'd need a whitepaper of the signal, and it's readings at various points of the board. you can try if the problem is obvious, but it is reasonably cheap to buy another motherboard. go to goodwill and get one of their towers and swap your mainboard out. to just clean it take it out and wash it in the sink in warm soapy water and get it very very dry before you try to replace it and put powet to it. electronics chemical cleaners in the can could be used as well, but the warm soapy water is just as good.
Posted on Oct 15, 2010
Is there a manual or step by step guide to take apart to re-wire a remington S1005 as my daughter has managed to split a wire by coiling it around the straightners when not in use...Everything works as...
dont take it apart just sauder the wires together and wrap with electrical tap should be good to go just make sure u sauder the same color wires together such as red to red and black to black etc
Oct 19, 2017 | Remington S6500 Sleek and Curl Ceramic...
My heat will not shut off i have a remote thermostat i can take thermo wires apart at ac unit and stop it
The thermostat is supposed to do the same thing you are doing when you take the thermostat wires apart at the ac unit - it's not.
I would replace the thermostat and see if that doesn't fix the problem.
good luck!
Mar 21, 2010 | Dometic Rooftop RV Air Conditioner
Ho do i take it apart
Check the wires in the back sometimes the wire may brake and if you know anyone that can solder very well they should be able to fix that easy.
Oct 18, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Water will not pump out, no hum or noise what so ever
TRY THE LIT SWITCH PUCH A PENCEL WER THE WASHER LID FRAIM THER WILL BE A OPENING 1INCH LONG THE IS WERE THE SWITCH GO
Jul 16, 2009 | Whirlpool Inglis IP4400 Washer
Wii drum symbol in world tour just quit
WIRES ARE VERY THIN.YOU WILL HAVE TO TAKE SET APART AND LOOK FOR THE WIRE THAT HAS COME APART . YOU CAN FIX THIS BY SOLDERING WIRE ,OR TAKE SET BACK TO PLACE OF PURCHACE. REMEMBER YOU WILL EVENTUALLY RUN INTO THIS SAME PROBLEM, WHICH YOU CAN FIX ON YOUR OWN.
Mar 08, 2009 | Nintendo Rock Band for Wii
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
thanks,
Nate
Aug 12, 2008 | Audio Players & Recorders
Battery charger wires-Can they be fixed?
If you can clearly identify which wire is which, simply strip off a half inch or so from each broken end, twist together, then solder or simply wrap twist with electrical tape. repeat till all wires are connected then tape into a single bundle. Zaak
Aug 03, 2006 | Toshiba Satellite A45-S250 Notebook
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
