Question about Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep
I have an ingersoll-rand upright compressor model 2545k10-p, 10 hp, 120 gal, 175psi compressor, and the electric motor will run for about 15-20 seconds and then automatically shut off, and be really hot. do you have a solution?
    Novelist:
  • 214 Answers
Does the motor rotate the compressor or just set there and hum? How old is this unit? Overload heaters may be to small or unit may be single phaseing. Is there air pressure in the tank when this happens.
Posted on Nov 14, 2010
Ingersol rand 80 gal 5 hp manual
follow the link
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-877.pdf
Sep 07, 2014 | Ingersoll Rand SS5L5 Ir Electric...
I have an ingersoll rand 30t model 253 compressor 80 gal tank. what should the start and stop pressure settings be? what is the run time to fill tank and cycle off?
Hi
I'm not sure but I operate my'n at about a 145/150 top and about 110/120 min.
However others my have a differant perspective
Cheers
John
Jul 09, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Hi i have an Ingersoll rand 80 gal, 7.5 hp, model #2475 air compressor and the electric motor is arcing when trying to run then blows the breaker. Any ideas? thanks
It sounds like either a problem with the brushes in the motor or the engine shaft is jammed. Have you on many previous occasions run the compressor on that circuit with no problems? It may be as simple as the breaker is not sufficient for the power draw of the compressor.
If you have had the unit for awhile and it has been run lots and the engine shaft spins easily when turned by hand (unplug first) then it may be an issue with the brushes on the electric motor. Take the engine apart and replace the brushes with new ones from an electric motor shop. Take pictures as you disassemble the unit so you will be able to refer to them when it comes time for reassembly.
If the motor shaft does not turn by hand, remove the belt that connects it to a compressor and try again. If this works, reconnect the power and see if the electric motor now works with power on and the belt off. If the motor works and there is no short to throw the breaker, then your compressor is in need of a rebuild and that will cost money and time.
Mar 15, 2011 | Ingersoll Rand Electric Driven Two Stage...
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
I had a 242-5D on a 120 horizontal driven by a 5 hp Dayton motor. I changed to a 2475N7.5 on a 80 gal vertical with a bad motor. I want to reuse the Dayton 5 hp motor. What can I expect?
Im not sure if iv;e got this straightYou had a 242running on 120 v driven by 5 hp dayton motor You have a new 80 gal tank with a bad 7.5 v motor and want to put the 5 v motor on it What was the size of the old tank if it was 60 or more you should be ok the 5 hp will have to work harder as long as you can make it fit you may want to consider droping down the blow out valve presssre spec 10 to 15 lbs depending on the size of the old tank
Nov 21, 2010 | Ingersoll Rand - Rand Type - 30...
My ingersol rand compressor shuts down on low unload sump
check minimum pressure check valve on top of separator cover.
Jun 30, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Compressor wired wrong from the factory and will not run.
I cannot find any diagram from this description. do you have a model # of motor?
Mar 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep Logo
368 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
