Question about Whirlpool LER4634J Electric Dryer
DRYER NOT HEATING, AND YES IT IS PLUGGED IN - Whirlpool LER4634J Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Nov 15, 2010
My frigidaire gas dryer will not heat
Good Morning Margie,
I see that you are having trouble with your Frigidaire gas dryer heating. I also see that the vent is plugged. You definitely do not want that vent plugged. Your dryer needs proper ventilation in order for it to work correctly. The reason it might not be heating is due to the fact that that vent is plugged and is not getting enough ventilation. Unplug that vent, make sure that there is gas going to the appliance, and that the gas supply valve is open.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire AGQ6000ES Gas Dryer
My Samsung DV5451AEW/XAA will not dry cloths. The vent tube is not plugged and air flow is great through the whole vent system. How do I get to the heating element?
  • I am assuming this is electric. Yes?
  • Do you get any heat when there is no clothes in it?
  • Have you checked your voltage at the receptacle? If not 220V, if you have the old tube fuses, then one may be blown. If you are getting good heat with no clothes then replace your high limit thermostat. Lots to check before heading for the heating element. As for heating element they are usually either in the back of the tub or a tube on the right hand side of the dryer. You need to take the front panel off.
Aug 03, 2013 | Samsung White Dryer Dv5451aew/xaa
No heat
Suprisingly enough, dryers that are not heating more often than not have a plugged outlet to the venting. Pull your dryer out, remove the vent tubing and make sure that it is not plugged. Also make sure that the opening in the dryer is not plugged leading to the venting.
Feb 10, 2011 | Kenmore 700 6972 Dryer
Quit heating
Hello there and thank you for choosing fixya
ok there are a few reasons why this happnes i will post them below for you
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Jan 22, 2011 | Dryers
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
Oct 02, 2009 | Irons
Installed a heating element but dryer dont turn on
Was dryer running, but not heating before? Could be a connection that was left loose upon reassembly. Check for tripped breaker in house electrical panel. Is cord from dryer plugged in?
Jul 12, 2009 | Frigidaire FDE336RE Dryer
Dryer not heating
Either the vent is plugged and the moisture is not escaping, or the element is no good. the failure mode for a dryer heating element is to open circuit.
Dec 14, 2007 | Whirlpool LER4634PQ Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
26 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
