Question about Epson C31C412144 Thermal Printer
Epson m129h leaves 1/3 roll paper and flashes out of paper. is there an adjustmen to fix yhis problem
5 Suggested Answers
SOURCE: epson 9800
Low Paper message on the LCD means that the media counter has been turned on and it is now at a point where the printer thinks that there is not enough paper to run a job. Here is what you need to do:
1) Turn the printer off
2) While holding the Pause Button turn the printer back on
3) Scroll down to Paper Count
4) Hit Menu to select
5) Scroll up to off
6) Hit menu again and a star will appear indicating that the Paper Count is off
7) Power down the Printer and then Power it back up
This should take care of it. If you have any other issues, feel free to contact me directly.
Sean McGettigan
sean.mcgettigan@lexjet.com
LexJet - www.lexjet.com
(800)453-9538
Posted on Feb 28, 2008
Stickx
  • 148 Answers
SOURCE: wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Posted on Jun 27, 2008
SOURCE: ePSON m129h pos PRINTER -- NOT EJECTING AND TEARING RECEIPTS
Finally used the hardware trouble shooter in my POS software program. Disconnected all the connections to the printer, shut down the program and workstation. Plugged things back in and YEAH!
Posted on Jan 15, 2009
  • 289 Answers
SOURCE: my epson m129h is disseminating
you should disconnect it first from your computer then go to printer &fax select the printer right click on it then select cancel all jobs
Posted on Jul 31, 2011
My epson m129h is disseminating a long printing paper when i power it on. Am unable to solve the problem, what could be the solution?
Jul 31, 2011 | Epson C31C412144 Thermal Printer
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
How to fix a paper feed error
To fix your paper feeder follow the mention tecnique:
1. open your printer paper feeder
2.put off spring
3. Then find out a white roll gide and open it.
4. Open roll gide from the printer. Then open black roll from white case. In the hole a spring apear . put off the spring from there.
5.Finaly assembel all the parts again without the spring.
I think your printer may work again. Thank you.
Aug 24, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Hi i have epson tmt88iv model m129h sirial to usb i need drive plzzzz
find your driver from these site
1)www.epos-store.co.uk/product_info.php/products_id/294
2)www.barcodesinc.com/epson/tm-t88iv-drivers.htm
Nov 10, 2009 | Epson TM-T88IV Printer
I need to down load drivers for my epson M129H printer
Hi calderon1of4
epson m129h printer drivers can be found at
driverupdate us .
It will take 2 mins from you to install... after updating, go to word and try to print something
I hope I have helped you...
enjoy
Oct 19, 2009 | Epson C31C412144 Thermal Printer
EPSON m129h pos PRINTER -- NOT EJECTING AND TEARING RECEIPTS
Jan 14, 2009 | Epson C31C412144 Thermal Printer
Epson C31C412144 Thermal Printer Logo
139 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
