Question about Garmin GPSMAP 4208 GPS Receiver
How nema wiring for garmin 4208
How do i wire twin Yamaha 150 outboards to Garmin 4208?
  • Anonymous Jan 07, 2009
    please help
2 Suggested Answers
bily8888
  • 14 Answers
SOURCE: I would like to hard wire my Garmin 265 WT to my
amigo , yo tenia el mismo problema de mapas de argentina con un gps de un tomtom y otro con sistema wince ,luego busque y me recomendaron un servicio tecnico en cap fed ,ya me lo solucionaron me cargaron mapas de toda argentina,ahora quedo barbaro !! te paso la pagina ,espero que te sirva ,salu2 http://www.mapeo-gps.com.ar
Posted on Jun 13, 2010
How to disassemle garmin 4208
If you have the correct soldering equipment and have the replacement part, it shouldn't be too hard. You'll need a jewelers screw driver to get the small screws out. Use a guitar pick to pop open the case. Work it around the case until the back half separates. Clicking and popping sounds are normal. Take out the battery wires. Do NOT yank on the wires... gently grab the plug and wiggle it loose.Remove the screws holding the board to the case to expose the solder side and remove the broken power jack.
Jul 17, 2014 | Garmin GPSMAP 4208 GPS Receiver
How to hook a uniden vhf radio to a garmin 4208 for nmea operation?
Hi
I realize this question is old, but for the benefit of someone else who might have the same query, the NMEA 0183 outputs from the 4208 are the gray (+) and black (-) which go to the data in of your DSC VHF. The data OUT from your VHF connect to the white (+) and black (-) of the 4208.
If using NMEA 2000, using the second link below, start on page 10.
The installation instructions are about halfway down on the link page and can be accessed directly from the install link below if you prefer. -Steve
http://support.garmin.com/support/manuals/manuals.htm?partNo=010-00591-01&language=en&country=US
http://static.garmincdn.com/pumac/GPSMAP_4000-5000_Install_EN.pdf
Apr 28, 2014 | Uniden Boating
2002 yamaha 150 outboard wont shut off with key
Broken wire in loom,white wire,bad connection in loom plug,if it switches off with kill switch,then it points to ign switch
Mar 15, 2014 | Clymer Marine Maintenance and Repair...
Connections problem
Question: What are the extra wires used for on the power cable for my fishfinder?
I found this on the carmin website under questions and answers. I think your cable is ok to use according to this.
--> Answer: Not all of the wires in the harness are required for use. To connect the unit to the power source, only the black & red wires are required (black to ground, red to positive). Here are descriptions of the other wires in the harness:
  • The Blue wire is used for a NMEA data out connection to another NMEA compatible device. The fish finder outputs NMEA 0183 version 3.01. The receiving device must be compatible with this format and looking for the NEMA sentences DPT, DBT, MTM, or VHW.
  • The Brown wire is used for a NMEA data in connection to receive data from another NMEA compatible device.
  • The Yellow wire is used to connect to an external buzzer or alarm to alert you to any alarms which have been set to sound on the device. The Yellow GARMIN wire connects to the negative end of the external alarm. The positive return on the alarm will connect to the red positive wire of GARMIN.
  • The green, white, and any other colors present have no connection purpose related to your fishfinder. The 18 Pin connector wiring harness is used by several other devices which utilize these wires.
If the device is only being connected to power & do not require a NMEA interface, PC connection, or external alarm support, only the red & black wires are required.
Jul 05, 2012 | Garmin Fishfinder 90
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
Oct 23, 2009 | ICOM Informatique Icom IC-M402 VHF Marine...
Where do all the wiring go to on the garmin 400c
The rest of the wires are for interfacing (letting the unit 'talk') with other devices such as radar or GPS. These wires/colors are pretty standard and defined by NEMA (National Electrical Manufacturers Association). You need wiring diagrams for the devices to hook them up. For fun, see where 'nema' takes you with Google.
Jun 18, 2009 | Garmin Fishfinder 400c With Dual Beam...
Garmin 4208
Make sure all three T-connectors are connected and that you connect the YELLOW cable to the last one. This yellow cable will need to be connected to power. Then you will get GPS link up.
Mar 22, 2008 | Garmin GPSMAP 4208 GPS Receiver
Non-Garmin GPSr
Garmin software will only work with Garmin hardware. Garmin does not use the standard NEMA protocol for GPS output, but their own. Also their software is tied to their hardware by a unit id, which require an unlock code in order for the maps to function.
Jan 22, 2008 | Garmin StreetPilot c550 GPS Receiver
No guage screen on my garmin 4208
Need more info:
Is your Garmin hooked up to your engine's computer via an NMEA 2000 data cable?
The gauge option will not appear in the menu if the GPS does not recognise the data coming from your engine. (If you turn on the GPS simulator, you should see the gauges on that screen.)
There are 3 possible reasons that the gauges do not appear in the menu:
1) improper wiring between engine and gauges.
2) GPS has not been set up to receive data in the GPS's NMEA setup menu.
3) Engine has not been set up to send NMEA data.
This is a relatively new feature that only works on newer engines that are NMEA 2000 capable, such as Volvo and Evinrude Etec.  The engines usually need an optional instrument package to make use of the NMEA 2000 system.
We're just scratching the surface here, please reply with any questions.
Oct 22, 2007 | Garmin GPSMAP 4208 GPS Receiver
Garmin GPSMAP 4208 GPS Receiver Logo
96 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
