Question about Lexmark X3480 All-In-One Printer
Printer says cover up all the time even when i put the cover down it still says it any clues
  • LXK Chris
    LXK Chris Oct 15, 2010
    Maybe the top cover sensor got stuck. Exercise it by opening and closing it again. Then, unplug the power adapter from the printer, replug after 30 seconds. That should give the printer enough time to reset itself. If the problem continues, contact Lexmark technical support.
  • 3 Answers
There is a small white switch that falls off if you can find it it needs to e reattached to a small black micro switch which is located just right of the middle of the lid where you see a sloping white piece of plastic
Posted on Oct 18, 2010
Canon MX 892 = Printer error has occurred. Turn off power than turn back on. If problem persists see the manual.
The grinding noise would be a clue that something needs to be put right before the reset would work!
Open the cover and check the paper has not jammed or cartridge has not been placed correctly.......remove cartridge and replace! Then turn off power and back on again!
Oct 19, 2014 | Canon PIXMA MX892 multifunction printer
I have a brand new 800 Epson printer, when I turned it on for the first time it keeps saying jammed paper and I haven't even put paper in it yet
I suggest you return it to the shop and ask for a replacement printer as it is covered by warranty. Do not try to fix it because you most likely will void your warranty.
Dec 05, 2012 | Epson Stylus Office Equipment & Supplies
I was unable to loace the Toner Cartridge. Could you please tell me where to open up and how to replace the tomer cartridge? Thank you. Regards, Lisa Li
Make sure that the printer is turned on. Open the front cover. Slowly but firmly pull the drum unit and toner cartridge assembly out of the machine. Push down the green lock lever and take the toner cartridge out of the drum unit. Unpack the new toner cartridge. Hold the cartridge level with both hands and gently rock it from side to side five or six times to spread the toner evenly inside the cartridge. Pull off the protective cover. Put the new toner cartridge firmly into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically. Clean the primary corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times. Put the drum unit and toner cartridge assembly back in the printer. Close the front cover.
If you want even more detailed information, there is a how to guide with ilustrations on each step on the Brother website.
Dec 07, 2010 | Brother HL 2140 Laser Printer
Where can i put lexmark ink?i can't see the place where should i put the new ink for lexkmark x2650
Make sure the Lexmark X2650 printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will move to the center automatically for the loading position.
Press the down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Nov 06, 2010 | Lexmark X2650 All-In-One InkJet Printer
Which model mazda mx5does not need a timing belt change
dont know ,look at the engine and see if it has a plastic front cover if it has then its a timing belt
Oct 21, 2010 | Mazda MX-5 Miata Cars & Trucks
Hey, this is the first time I am changing the ink cartridge but it doesn't want to come out, even after I press down on the green button. Why? Anyone know?
First open the front cover, you have to pull on the handel in the middle of cartidge with some force to take out of machine. You can put it down on a table, then press the green button to remove the grey toner cartridge out of the black drum unit. Then put new toner in drum unit and put back into machine
Apr 09, 2010 | Brother HL-2170W Laser Printer
Xerox 8400 Error 07.010.43:97096
printhead got stuck.....possible ink spill.
if u are a printer tech. then you would have to pull out the printhead and clean the area by the base of the printhead also check that the plastica Retainers(of the printhead) are not broken,then put it back.
Jul 31, 2009 | Xerox Phaser 8400 Laser Printer
Hi, I refilled my black cartridge and since then it starts printing but always comes up with error code 5200, it does not even put ink on the paper. I have tried all the usual tips like moistening the...
Have you put the black label back right. It will only work properly if you have the top near the 2 straight lugs. If it is down low near the curved lug then it will block the chip! Make certain that ink hasn't covered it up too.
Jul 07, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Britax Car Seat First Class SI
i took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
Sep 03, 2008 | Britax Eclipse Si - Paris Convertible Car...
Printer Head Cleaning
It's in the blue plastic cover. Power down the SP75. Open cover to see the printhead. You'll see a green stripe. The printhead is in front of the stripe. Use an alcohol pen to run back and forth over the printhead. Do not drip alcohol onto the print ribbon. Allow a minute or two for alcohol to dry before reclosing the cover.
Nov 28, 2007 | Datacard Group SP75 Color Card Printer
Lexmark X3480 All-In-One Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
