In most browsers the backspace key will return you to the page you were at before you arrived at your inbox. To make sure this doesn't happen, make sure you are clicked inside the place where you type your message, and make sure there is the blinking line, like normal :)
Try function and scroll lock at the same time the try to enter the password, if this does not reset your keyboard, remove the power and the battery for 3 minutes then turn it back on and try again.
if the other keys are working, you need to check if there isnt anything underneath the key which could be physically blocking it to be depressed. let me know
Restart your computer to turn off the "Sticky Keys" accessibility tool.
Use "sticky keys" if you have limited finger dexterity capability or limited motor skills.
For example, you can press CTRL and then ALT and then DELETE,
rather than having to press all THREE keys at the same time.
To the RIGHT of the "space-bar" on your keyboard is the 'ALT(ternate) GR(aphic)' key. Hold-down that key, and press the '?' key, and a '?' should appear on your computer's screen.
you might have sticky keys permanetly stuck on, ive had this problem, it worked after i held down shift and press the backspace key, then it worked nomally again. hope this helps.
