Question about JBL Media 100 Computer Speakers
JBL Media 100 speakers are properly connected, but no green light on front. On a steady red light, and no sound from either speaker. Help!
punker0204
  • 54 Answers
SOURCE: Installing speakers jbl
the red and white x indicates that your speaker is in mute mode. you just have to click that speaker icon and uncheck the mute. then you'll hear a music thats for sure.
Posted on Sep 18, 2007
lil_smurf
  • 7 Answers
SOURCE: JBL Media 100 Speaker power?
Buy a power adapter from radio shack or similar place. You need a 1000mA 12 volt dapter. Just make sure it is rated @ or above 1000mA to avoid the adapter heating up and possibly burning. The whole setup is rated @ 850mA wich 1A(1000mA) should handle with enough head room. But it might run you about $15-20. I would just buy a cheap radio with rca inputs/aux input and use that. I got one from Walmart for around $40 and it plays CD's & AM/FM.
Posted on Jun 09, 2009
  • 3 Answers
SOURCE: driver jbl pro speakers
I use these speakers since 2000. It will be 9 years this October!!! They work very good. I never used any drivers for them. I changed three computers with different mother boards / sound cards and they worked fine with any Sound Manager I tried.
Posted on Jun 28, 2009
lil_smurf
  • 7 Answers
SOURCE: What is the dc input for JBL Media 100
They run @ 12 volts 850mA. So an adapter with center pin positive at around 1A(1000mA) would give it enough "headroom". This means it would run cooler and last you longer. Amperage consumption is determined by the power it is producing, how loud you are playing the setup.
Posted on Jul 24, 2009
SOURCE: JBL spot series speaker not working.
I know this is old but just incase anyone has the same problem. Its proabably the connection from back panel to the internal amp (Inside the sub enclosure). The ribbon cable has the + for the left speaker right at the edge with quite a bit of tension. Over time and with the vibrations from the sub this will bend/pull out slightly and needs to be pushed back on and some hot glue put around the connection to hold it in place.
Thats how I fixed mine anyway.
Posted on Feb 22, 2010
Toyota Camry 2003 V6 radio
2006 Toyota Camry Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jun 16, 2016 | Toyota Cars & Trucks
JBL Radial -iPod audio system
It should produce sound from al speakers, I see if I can find a schematic.
Oct 29, 2008 | JBL 6-1/2\ Round Coaxial Speaker By...
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
Want to connect JBL platunum series speakers to Dell Inspiron 560 with Windows 7. There is no sound coming from theses speakers on this system. They worked with HP compac.
Hello there,
here is the sound card for the DELL
Sound Card Integrated 7.1 Channel Audio up to Creative SoundBlaster® X-Fi Xtreme Audio (D)†
that means you have a sound card and the port should be in the back and should be green.
Audio front panel - one headphone and one
microphone connector
This is for a headset .
Here is what i would try make sure the speakers are powering by turning on the right speaker the LED should light up if it is then it has power, Next i would try the back of the PC speaker port , if you have everything connected correctly we move onto the next step.
Ok go to
Control panel
Hardware and sound
then click on the green sound link that should pop up a window to configure the speakers, you should see the devices in the list and be able to configure them if you do not let me know and i can help you with the next step.
thank you don't forget to Rate
Jan 25, 2011 | HP JBL Platinum Computer Speakers
How do the wires go into the back of the creature?
First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
JBL Creature 2 are a computer speaker system designed and sold by JBL. The system is made up of two satellite speakers and an omni-directional subwoofer. The speaker system connects directly to a computer's available sound card output jack or a laptop's stereo output jack. Occasionally, problems can occur with the sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable connections. Ensure the satellite speakers are firmly connected to the matching jacks on the back of the Creature's subwoofer. The connections are color coded and, in addition, each speaker connector is shaped differently to fit only into one jack. Ensure the output cable is firmly connected to the subwoofer audio in jack and the computer's audio-out jack. Ensure the power button on the back of the subwoofer is pushed inward. If everything is connected properly, the green lights on the underside of the satellite speakers will glow.If there is still no sound, tap the right-hand side audio-increase button on the right satellite speaker until sound is heard. Also ensure there is audio playing from the computer. Double check the lower right-hand side of the window's main screen and look for a speaker icon. If the icon has a red slash over it, click the icon and uncheck the "mute" option.
Hope this helps
Dec 30, 2010 | JBL CREATURE II Computer Speakers
Need a wiring diagram for a 2003 toyota camry with jbl audio system
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: 6′ x 9′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
pls rate
Aug 07, 2010 | 1998 Toyota Camry
JBL Speakers won't play
Check all your connections. it might be that the green audio jack isnt put into the rear of your pc properly.
Jan 02, 2010 | Audio Players & Recorders
Can't get sound JBL Media 100 speakers/ subwoofer with mac
I am not sure what the extra lead is for. The instruction book should make it plain how it should be connected. If you have no instructions perhaps they can be downloaded from the manufacturer's website.
My 5:1 speaker system is prewired and has only one audio in lead and a socket for the power supply. The audio lead of such speaker systems is generally equipped with a 3.5mm stereo jack plug intended to be used in the headphone socket of computers, tv's, radios and anything with a headphone socket, even phones.
Once you are certain the speakers are properly connected they should work if there is audio present at the headphone socket of the Mac. A known pair of headphones can be used to test this and conversely the speakers could be tested by plugging them into any other known good audio source.
The presence of an RCA or phono plug/lead is confusing as these aren't usually associated with active speaker systems for computer and general use but rather for more serious audio such as connections between an amplifier and peripherals or cinema surround sound. Such a system probably wouldn't be suitable for use with a computer...
Apr 01, 2017 | JBL Media 100 Computer Speakers
JBL Media 100 Computer Speakers Logo
134 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
