Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
PT61LCX65 lamp timer
Can you email me the instructions on how to reset the lamp time after i already replaced the lamp unit?
Thank you
  • Anonymous Mar 16, 2014
  • 208 Answers
Hold the volume down button on the tv until the volume is at min. then continue to depress the volume down button on the TV. While depressing the volume down button the tv hold the pip or split button on your remote for approx 5 sec. You will see a box pop up that says lamp timer reset and gives instruction on how to exit.
Posted on Jun 10, 2008
I have a pt61lcx65 DLP panasonic and i just replace the lamp on it. now when i turn it on the indicator lamp blinks green then yellow. i dont know how to reset the lamp timer. could that be the problem and if so can you send me the solution?
Posted on Oct 23, 2008
How do you replace the lamp for a panasonic PT-50LCZ70
To replace the lamp of your Panasonic Projection TV do the following. Read these instructions carefully and then try to do the job.
1. Turn the power off, wait until the power indicator turns off blinking red, then unplug the power cord from the wall outlet and confirm that the area around the lamp unit has cool down.
2. Remove the front cover procedure. Place your finger tips under the cover and pull it from the projection display.
3. Before loosening the lamp cover screw, first read the caution and warning labels in the lamp cover. Then loosen the lamp cover screw by using a screwdriver.
4. Loosen the lamp unit screw with a screwdriver. Then grasp the lamp unit, Figure 2, by the lamp unit handle and slowly remove it from the projection display.
5. Insert the new unit being careful being careful of the insertion direction. Press in the arrow mark making sure insertion is done correctly.
6. Replace the lamp unit and cover screw. Tighten the unit cover screw with a screw driver.
a. Properly dispose of the old lamp. Please see the operating instruction of the projection display unit.
b. NOTE: attached the lamp unit and lamp unit housing door securely. If the lamp unit and the lamp unit housing are not attached securely, the protective circuit will be activated and the lamp will not turn on.
7. Replace the front cover.
The second step, after lamp replacement is to follow the three steps procedure described below:
Warning: Perform lamp time reset only when the lamp has been replaced.
In order to complete the lamp time reset procedures:
1. Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button the projection display or the remote control to turn the unit on.
2. While pressing the VOL - button, hold down the PIP or the SPLIT button on the remote control at the same time for more the 5 seconds.
3. When the reset procedure is complete, the projection display screen will show the following message "Lamp time was reset to 0."
1. The writing in the screen may be different from the actual screen described above.
2. When lamp time reset is finished, the lamp indicator goes out.
Feb 23, 2011 | Panasonic PT-50LCZ70 50" HDTV
How to reset the lamp timer on Sony Projection TVs.
If you have replaced the lamp in your Sony projection TV you must reset the lamp timer to get rid of the message saying that your lamp needs to be replaced. Let's face it, you know you already accomplished replacing the lamp but the TV isn't smart enough to know that. I will explain in detail how to accomplish the reset procedure.
Resetting the lamp timer is a complicated procedure but you should be able to do it if you have plenty of patience and know how to follow instructions. Read the procedure over first several times before trying to do it and locate all the buttons on the remote. You may want to try the procedure on the remote to make sure that you have the sequence memorized.
By the way the lamp life is figured to be from 5000 to 8000 hours. That is not much time if the TV is being used for more than 8 hours per day. If you do the math and watch your TV for 8 hours per day (not uncommon) the lamp will need replaced in 3 to 5 years. So be ready to do this procedure again in the very near future.
Here is the procedure.
All commands should be done using the factory remote:
1) enter the service mode by pressing display, 5, volume +, Power on
2) press JUMP 3 times
3) to display the time press channel 2, 9 times
4) to reset lamp timer press channel 3, MUTE, Enter
5) to check the time press channel 1, 7 times
6) when complete turn set off to exit.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
on Oct 30, 2010 | Televison & Video
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Lamp hour reset
I don't thing that because you were not reset the time lamp used now your LCD projector stop function
What was exact the unit did? no power at all or some LED light up or flashing. In any case to reset the lamp time use you must enter when unit is on
As you mentioned you did replaced the new lamp, You should check again if you reinstalled properly the lamp and lamp cover because under the lamp cover it had a safety switch if this SW not active then the unit will be in protection mode
I sugges you to remove again the lamp and reinsert properly and secure the lamp cover and try it again and if it still is not go then let me know what are the status of the 2 LED
Dec 24, 2008 | Office Equipment & Supplies
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
SPLIT for Models:
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Need assistance and the email you've been send others to help
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 12, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Toyota Land Cruiser check timimg Belt
I am assuming that you have a series 80 diesel engine and that it has run for about 100,000 kms hence the warning light and the changing of the timing belt. Based on the instructions of its repair manual you need to "remove the grommet off from the speedometer and turn off the lamp by pushing the warning light reset switch, then replace the grommet." Alternately, you can try to reset the entire computer of the vehicle by removing the battery cables for a couple of minutes. Pls note that some car radios/head units would revert to security default (ask for a code) when power is completely removed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 24, 2008 | 1997 Toyota Land Cruiser
Lamp replacement
The file is too large to post here but if you post your email address, I can send you the step by step instructions to replace the lamp and reset the lamp hour counter.
Mar 01, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
359 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
