Question about York Yankees Bedding MLB Comforter
How do you twin model#p4huc20n08001a furnaces
UGDG-07EAMGR
Pressure switch ?
Nov 17, 2016 | Heating & Cooling
Greenlight flashes 5 times on furnace
Will need more info: Make, Model etc.
Sep 13, 2014 | Heating & Cooling
Rheem furnace ,2nd green light blinks 5 times then pauses. I have only 1 furnace,not a twin
5 flashes is a "neutral polarity failure".
on the motor:
White is the neutral and must be plugged in to one of the 3 neutral slots on the control board (usually on the left side of the board)
The other 4 wires (black, red, yellow, brown) are power to the motor and should be connected to the appropriate pins on the control board.
ref: http://www.rheem.com/docs/FetchDocument.aspx?ID=d0613a32-db55-4e32-abfd-04e89e72f7a6
What are twinned units?
Twin units can be two airconditioner condensers and/or two furnaces. Most manufacturers make a twinning kit that will wire two units together to operate simultaneously by one thermostat. At times, one may operate as a first stage of heating (cooling) and then the other unit can operate as second stage. Twinning unit are beneficial in commercial buildings where the load conditions vary constantly. For instance, if you twin two 4 ton units together. On a nice cool day, you may only need 4 tons of air conditioning. So, the thermostat will only turn on one unit. On a hotter day, you may need 8 tons of air, so the thermostat will turn on both units. In case you are thinking about doing this, the biggest mistake in twinning units together is using a common return air for the furnaces. Make sure you separate the return air cavities and ductwork for both of your furnaces If you don't have separate returns, you have the possibility of one of the blowers starting backwards. (talking form experience LOL)
Aug 13, 2011 | Heating & Cooling
Coleman evcon wrong polarity or twinning error what does this code mean
It will probably means you have your hot and neutral wires crossed. The furnace has 120 volts coming in to it from your house. If the hot and neutral wire are wired to the furnace wrong, it will show this error. Take the electrical box loose where you can see the power cord coming in to the furnace. (turn off the circuit breaker to the furnace) Take the white and black wire loose , connect the black where the white wire was and the white where the black was. All you are doing is reversing polarity. I hope this works for you.
Apr 18, 2011 | Coleman Heating & Cooling
Can i install two furnaces w/refrigirated air into the same duct system w/ 1 thermostat
It's called Twinning. And as long as the furnaces can communicate with each other and the duct system can handle the combined cfm, yes. You will probably need two thermostats but have a heating professional look at it.
Mar 03, 2010 | Heating & Cooling
York high effenciency furnace not firing all the time
has anyone worked on this furnace because the error would indicate that the positive 120 volt and the neg 120 volt is swapped , these units will also do this when the ground wire to the furnace or gas valve or furnace or @ the panel is lose , corroded , or missing , the gnd must be present to open valve , I am aware that ac is is not usually polarity sensitive but in this case it most certainly is ...have seen many time and know it to be true
Dec 27, 2008 | York Yankees Bedding MLB Comforter
Erratic goodman GMPN 100-4
sound like you have a bad fan motor
Dec 04, 2008 | Goodman CPLE24-1 Air Conditioner
Model # GMPN100-4 Furnace will not start...
when you remove the panel there reset button press on it
Jan 18, 2008 | Goodman GMS90703BXA Heater
York Yankees Bedding MLB Comforter Logo
103 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
Brandon Berry
Brandon Berry
Shehu Pro
Shehu Pro
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
