Question about Xerox Phaser 8200 Laser Printer
Paper Jam - Xerox 8200 Phaser Printer
When I turn it on, I get "Paper Jam - open exit cover to clear" but there is no jammed paper anywhere. When I open the exit cover, I see a daggling short dense coil that was possibly originally connected somewhere (& could be the problem)
Anyone has seen such thing and knows where the coil is connected to?
Any help will be much appreciate it.
I was same problem and I repaired. In to machine, look of preheat switch ( behind of black roller ). I found piece of paper under the switch. Good luck :)
Posted on Sep 07, 2008
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here:
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
Paper jam error comes up and can't clear it. Doesn't appear to be any paper stuck in printer anywhere
please double check again your printer by re-opening it.
look very carefully maybe there was still a small paper inside your printer.
after that try to turn it off your printer then afer 5 mins yiou can turn it on again.
any changes happen and further question don't hesitate to contact me.
Mar 21, 2009 | Xerox Phaser 8200N Printer
Phaser 860 screen says "paper jam - open front cover to clear"
I posted a problem with the phaser 860 paper jam. I found 2 broken sensor flags and am ordering the parts.
Mar 19, 2009 | Xerox Phaser 8400 Laser Printer
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Phaser 4510 claims repeated paper jams
The fuser exit sensor had an updated version for that model (old model has a "bounce" problem). Xerox gives a 1 year warranty..I would get them out to fix it pronto !
It is also helpful to have the error code. Press the i button while the printer has the jam message on the front panel. Use the fault code to locate where the jam actually is. (This will help the technician greatly ! )
Jul 29, 2008 | Xerox Phaser 4500 Printer
Lock down
Is sounds like your exit sensor actuator has been knocked off. It's not seeing the paper hitting the exit sensor and shutting down.
May 08, 2008 | Xerox Phaser 8200 Laser Printer
Paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
May 03, 2008 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 8200 Laser Printer Logo
399 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
