Question about Gateway Computers & Internet
My Gateway nv5378u laptop will not turn on. It's been working fine yesterday i turned it off and when I came back to it later that evening it would not come on. The charging light comes on when its plugged in but other then that I get nothing. I press the power button and nothing happens.
  • achaulk849 Jul 19, 2011
    Yes i got it fixed it was still under warranty at that time so i had to take it back to bestbuy. That was 9 months ago now im having another problem with it . Im not sure whats wrong with it this time and its no longer under warranty . but if i turn my laptop off or let it go to sleep it will not come back on, well it comes on you can hear the fan going and the lights come on but the screen stays black sometimes it will do this for days and then just come on and work normally its the craziest thing ....Most likely this will be the last Gateway ill ever buy
Sure
Posted on Jul 17, 2011
  • crazy_park12 Jul 17, 2011
    dud you get it fixed i have the same problem. iv tryed the power button trick new battery new ac power cord and i think its the power button... dont know how to cheack that though
    Yes i got that problem fixed, the laptop was still under warranty so i just took it back to bestbuy and they fixed it that was nine months ago now im having a different problem. Any time I turn my laptop off or let it go to sleep for some reason it doesn't come back on ,Well it does come on you can hear the fans going and the lights come on but the screen stays black it will do this for hours sometimes days and then just come on and work normally its the craziest thing. Most likely this will be the last Gateway i will ever buy ...
How do I turn on internal microphone in my NV5378u laptop?
Check it is not muted by right clicking on the loudspeaker icon and look at recording devices.
May 29, 2014 | Gateway NV5378u Notebook
How to turn on a NV5378u gateway laptop
1. Charge the battery for 2 hours,
2. Press the power button.
If the laptop does not start, you can do this:
Please use the VGA port (VGA external monitor), also please do these:
1. Unplug the AC adapter,
2. Remove the battery,
3. Remove the hard drive,
4. Press the power button and hold it for 15 seconds,
5. Plug in the AC adapter,
Restart the laptop.
If the problem persist,
Note: Do not insert the battery, and do not install the hard drive.
2. Reseat the memory (remove it and reinstall it),
3. Plug in the AC adapter,
Restart the laptop.
If those actions do not solve the problem, then your GPU/motherboard is dying.
Mar 09, 2014 | Gateway NV5378u Notebook
I have gateway nv53,it's not turn back on....looks like it's a hard drive problem,can i save the stuffs ,docs,pics and programs that was that before?
If you purchase a new hard drive and install an OS, you can then, with a usb hd adapter, copy your data back over.
Dec 24, 2013 | Gateway NV5378u Notebook
My Gateway nv5378u Laptop Fan makes a horrible noise when turning on.
fan is hit something or worn out take it and have it replace before you burn the processor up .good luck
Jan 16, 2013 | Gateway NV5378u Notebook
Nv53 gateway laptop will not turn on, power brick is green,it just won't turn on
Please take out the battery then plug in your power strip, press and hold the power until it comes on.
Let me know if this works. What could be happening is the system went to sleep and was not responding to user input, so this would be a way of a hard reset for it. Let me know if it works or not, as the next step is a little invasive.
Sep 21, 2011 | Gateway NV5378u Notebook
My Gateway NV53 has just stopped charing period. The Computer doesn't even reconginize that the charge cord is in. Can someone help?
This happened to me a couple times, the first time, I had to send my computer back to the factory because the DC board was defective but the second time I just had to leave my charger unplugged for an hour or so and then it worked fine. Sometimes, the charger will heat up to a point where it shuts itself off before it literally starts to melt.
Hope this helps, Nathan Taylor
Jul 21, 2011 | Gateway NV5378u Notebook
Even tho my web cam says working properly it is not i can not find where to turn it on at > or it doesnt work on oovoo
Install Yawcam from http://www.yawcam.com/
If it works with that, it should work with oovoo. Double check your driver settings.
Cheers
Mar 19, 2011 | Gateway NV5378u Notebook
My nv5378u does not turn on, all i get is the battery light blinks 5 times. help please.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Sep 26, 2010 | Gateway NV5378u Notebook
Laptop will not turn on
try remove your battery n insert again...or try use ac adapter without battery
Jul 31, 2010 | Gateway NV5378u Notebook
Need laptop manual on model#nv5378u
User manual can be found in the laptop itself , Go to Start Menu-> Programs-> Gateway Documentation -> Usermanual or quick guide Or got to Gateway -> recovery manager-> restore -> resote application and driver -> manuals
Jun 09, 2010 | Gateway NV5378u Notebook
Computers & Internet Logo
409 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
