Question about Emerson Threaded 1.5hp Fullrate 115/230v
Motor will turn over when turned on solid humming sound
    President:
  • Emerson Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Oct 15, 2010
2 Suggested Answers
  • 8404 Answers
SOURCE: turn on pump and it only has a humming sound
Check your start capacitor. Probably best to remove the motor and take it to your pool supply place.
Posted on May 16, 2010
The paddle on my kitchenaid won't turn. It just makes a humming noise. Any suggestions?
Is the humming noise the sound of the motor straining to turn without moving (it won't last very long like that) or the sound of the motor turning but not operating the paddle?
Dec 21, 2014 | KitchenAid Food Mixers
My Intex sand filter hums when i turn it on but won't work. Why?
if the motor just humms it sounds if the pump is not turning , do you think maybe a piece of something solid may have gotten in there (for me it's maple tree seed hulls) im getting them out of the pipes more than i care too
Jun 16, 2014 | INTEX Sand Filter Pump
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Sep 12, 2009 | Kenmore 73952 Gas Dryer
When we push the on button, you can hear a hum,
Sounds like the belt that turns the drum has broken. the hum sound is the motor turning. Does it still get hot in the drum? If so then you need a replacement belt ($15-$25).You can open the rear or the dryer to confirm the belt is broken. Be sure to unplug from the wall outlet to avoid electrical shock.
Aug 18, 2009 | Dryers
Dryer motor just hums
Sounds like the belt has been stretched and is not letting the motor turn the drum. If the motor is not turning at all then your motor is burnt out and needs ot be replaced
May 22, 2009 | Dryers
Hoover SteamVac Dual V Carpet Cleaner just hums when I turn it on
if the motor doesn't run sounds like you either have a bad motor or your motor armature might have gotten wet and created a dead spot.if you have any contact cleaner spray a little on the armature then turn the motor by hand make sure its uuplugged first if you can turn the motor then plug it in and try to start it
Apr 04, 2009 | Vacuums
Whirlpool side by side GS6NBEXRS01
If nothing is blocking ager .. sounds like motor bad or something binding it up. If you took in out and cleaned all ice out and still dont work with no ice.. sounds like motor ..if it hums power is to motor
Aug 28, 2007 | Whirlpool GS6NBEXR Side by Side...
Emerson Threaded 1.5hp Fullrate 115/230v Logo
91 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
