Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE SIDE BY SIDE MODEL # GSL25IFRF BS
NO WATER OR ICE @ DOOR...WAS INTERMITTENT...NOW NOTHING. ? THANK YOU. REGARDS , MARK
  • 2 more comments
  • stinkyfinger Oct 23, 2008
    Same issue ice-maker makes ice but won't share any and never gives water, light goes dim and freezer turns of when you try to get ice.
  • jamesthood Oct 28, 2008
    Exactly the same as original poster's problem.
  • rjc74 Oct 29, 2008
    i have the same exact problem. i just hooked up the water line today. water works most of the time, icemaker makes ice, when you dispense ice, light go dim.
    are there any solutions available yet?
  • chato6966 Nov 06, 2008
    Our Ice maker is no longer making ice and the water is dispensing intermittently. We have cleaned out lines we have bought new filter and nothing!!!!
    Champion:
  • 210 Answers
Did you change water filter?
Posted on Jul 22, 2008
My freezer has stopped freezing on my GE
sounds like the compressor has quit running or there is a Freon leak... either way it looks like a sealed system issue..... on some ge models if the cond fan motor quits it will heat up between the ref and fzr doors....
Oct 09, 2014 | Refrigerators
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
I have A GSL25IFRF bs side by side fridge with ice and wter dispenser on the outside and I am not sure how to connect it to work so I can get ice and water
On the back right side facing the refrigerator at the bottom is a connector for a quarter inch water line. Sometimes you have to loosen the back to access this. Hook your water line up here.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Nov 17, 2008 | Refrigerators
Water dispenser not working
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
954 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
