Question about Zenith R57W46 57" Rear Projection Television
Zenith projection tv model r45w46
We are having issues with convergence, were out of town for two days tv was off, now we get the 3D effect with green and reds, tried auto convergence, even with the screen covered as suggested by someone, no help, small popping sound during las convergence
  • Zenith Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
zenith projection tv model r45w46 - 3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
  • 556 Answers
Convergence IC's and possibly some low value resistors need to be replaced.
Posted on Aug 20, 2009
R56wh78 im having a problem.. the tv started the 3d effect so i replaced the convergence board.. and fixed the problem for about 2 days (convergence is still good).. now im having a new problem.. the tv...
The Deflection Power board is the the most likeliest cause of the dead set issue, and that could have also caused the prior issue of convergence board since the deflection board supplies all base voltages for the convergence circuits
Aug 16, 2011 | RCA Televison & Video
Convergence is wacky. Have spent hours in Menu-Picture-Convergence, but red won't align and so forth. Any ideas? Fixes? Workarounds? I am unemployed, so fix must be El Cheapo.
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 17, 2010 | Zenith R45W46 45" Rear Projection...
Zenith R45W46F has sound but no picture
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 27, 2010 | Zenith R45W46 45" Rear Projection...
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
3d effects
it will cost between $300-$700 to fix the convergence a new board was needed.... dumped the Zenith got a RCA LCD 40inch
Jun 22, 2009 | Zenith R57W46 57" Rear Projection...
3d affect
have the dm board checked
Sep 08, 2008 | Zenith R57W46 57" Rear Projection...
Zenith model R45W46 large screen HD TV went out altogether - video and audio Purchased in June 2004
I need a replacement screen for this R45W46. If you didn't get your fixed I would be interested in purchasing it from you. Contact me at: codywheeler1984@yahoo.com
Jul 30, 2008 | Zenith Televison & Video
Zenith r57w46
replace convergence i.c.s. and safety resistros around block
Jul 07, 2008 | Zenith R57W46 57" Rear Projection...
3d effect
Sounds to me like your convergance amps are on their way out...
Nov 21, 2007 | Zenith R56W36 56" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
135 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
