Question about Canon MV630i Mini DV Digital Camcorder
How to transfer videos from canon MV630i camera to pc by TAPE option?
SOURCE: video problems
If your camcorder is a digital version, you should have a 1394 iLink Firewire cable which is needed to connect your camcorder to your PC. A Firewire is a higher transfer rate connection than USB 1.0 (but slower than USB 2.0), and it is intended for applications such as video editing. Some camers, e.g., Sony, require a Firewire connection to exploit certain features of a digital camcorder and editing software, and it's best to use one. If you do need the Firewire but your computer doesn't have a 1394 Firewire port built in, you can purchase a PCI card version for around $50 and install it separately very easily.
And if your computer doesn't have the 1394 port, but does have a USB 2.0 connector (all newer computers now do), then you can connect your camcorder to your PC via the USB 2.0 (note: NOT a USB 1.0!) to begin capturing video. If you're still having trouble, make sure you go to your camcorder manufacturer's website to download any relevant drivers then retry your connection. If your computer Finds New Hardware sucessfully, you're in. Good luck!
Posted on Feb 22, 2008
leethedeuce
  • 4472 Answers
SOURCE: How does one transfer the video or 'still pictures' from Canon DC210 Camcorder onto their PC?
All you should have to do is finalize the disc. Put it in your DVD drive and select the scenes and photos. you need to have DVD playback software to play the disc also if its a DUAL layer disc you have to make sure the drive in your PC can play DL.
Enjoy,
Lee
Posted on Jun 12, 2008
  • 435 Answers
SOURCE: i need to import video from my canon zr500 to my pc
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Posted on Dec 29, 2008
gcrcomputers
  • 170 Answers
SOURCE: need device driver Canon ZR70 MC video camera
Here is the drivers page for your product:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=227&modelid=8619#DownloadDetailAct
Hope this helps,
David
If my solution helped please rate accordingly
Posted on Mar 17, 2009
  • 497 Answers
SOURCE: cant transfer videos to pc
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Option 3:
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 18, 2009
No luck hooking video camera up to TV - no picture
have u checked to see if the camera is PAL or NTSC? If your TV is one and the camera is the Other, then chances are you will not get a picture.
May 12, 2012 | Canon MV630i Mini DV Digital Camcorder
Hi, Canon 630MVi, after turning the camera on "EJECT THE TAPE" appears in the display, I try to eject the tape but alas to no avail , the tape compartment opens, but not fully.. Anybody have any...
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Mar 14, 2011 | Canon MV630i Mini DV Digital Camcorder
Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Jun 25, 2009 | Canon MV750i Mini DV Digital Camcorder
Transfering video to Mac
I believe that camera only works with firewire. You might want to check with Canon to see if there is compatibility problems with Macs. I know it works on Windows computers.
Jan 17, 2008 | Canon ZR800 Mini DV Digital Camcorder
How to use the MV6401 as an AD converter
There are more direct way of transferring VHS to digital format (MPG, AVI, etc. There are now cheap video capture devices like TV tuner, or a video capture card tha connects to USB 2.0 port. However if you still want to use this camera, this ?s what you need to do. 1. Connect the camera to the PC. Most MiniDV cams have an iterface called i-link, firewire or IEEE-1394. If your computer has no shuch interface, you have to install. 2. Record the analog video to the miniDV tape. 3.CApture the recorded tape to the PC. You need to video capture software to do this. You may need to convert the format to the format that you prefer. 4. Burn the vdeo to DVD, you will need a burner and video autthoring softare such as nero.
May 28, 2007 | Canon MV630i Mini DV Digital Camcorder
No software please help!
You dont need any specific software. I have the same cam. And the Microsoft movie maker reginized the cam. But I use Adobe premiere. Should be able to use any video editing software.
Dec 14, 2006 | Canon MV630i Mini DV Digital Camcorder
Canon MV630i Mini DV Digital Camcorder Logo
463 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
