Question about Motorola Mobility RAZR V3
Motorola razrv3 the screen has stopped displaying the menu it is just a mostly one colour which changes colour any advice can I fix it myself
    Brigadier General:
  • 7,752 Answers
Have the LCD replaced......yes you can fix it yourself but you should take it to a mobile repair center to have that done.
Posted on Jun 28, 2008
Is it ok if i use the charger for my w259 for my razrv3?
Only if you know for sure that this charger electrical transformers inside the charger will not damage your razrv3, because even though it may fix the internal charger components are specially for the product it was made for and if you attempt to use for another product you better be sure , otherwise, you cause damage to the other product it wasn't made for. It's best to get the correct or proper charger for that product
May 05, 2012 | Motorola Mobility RAZR V3
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
External display stays lit
You have the option to change it under display settings in ur main options menu. menu>system settings>display settings>front screen(?)>desplay timmer. This should do the trick. I have mine on 10 seconds and that works great. I hope this helps.
  `Nbryson
May 27, 2009 | Motorola Mobility W510 Mobile Phone
Display problem on Compaq Presario C310ea
problem in virus and second ram any one is problem in your laptop ..........ok fist cline your computer throught the antivrus program and not solve change the ram
Mar 31, 2009 | HP 435768-001 - Compaq Presario C300...
Faulty Display
It could be a bad connection in the wiring between your display and the keypad. You should get it checked out at a cell phone store especially if it's still covered under warranty.
Jul 04, 2008 | Motorola Mobility W375 Cellular Phone
How to replace the LCD screen for motorola Razr V3
First it should work when you turn it on.you should always hear a sound then you press a button.if it is dark screening it is your flex cable that need to be replace.Take it to a repair store
Jun 13, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorola razr v3
forgot my password for my motorola razrv3 can you help me to unlock it
Jan 28, 2008 | Motorola Mobility RAZR V3
Bright screen with very low contrast
I fixed it myself, it seems that the monitor have some problems remembering it's settings and sometimes it automatically set its settings to crazy values that are out of the range that we are allowed to input. For my case, the setting that was crazy was the gamma setting since it was set so high. I wasn't able to bring it back to a normal setting so I found a way to do it by resetting the monitor. So to reset these display settings such as colour, contrast, brightness and gama, you need to turn on the monitor and unplug the monitor without turning it off and plug it back in again. It will automatically power on and the correct default settings will be present.
This forum isn't very helpful is it?
Dec 09, 2007 | LG Flatron L1811S 18.1" LCD Monitor
Lcd viewer is not functioning
Hello, in this case there is a broken flat cable called FP-185 pn:186476111. You should also replace the cover pn: 218843302. Best option for you is to contact the nearest Authorized Sony Service. If you need more info please advice
Mar 10, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Motorola Mobility RAZR V3 Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
